Hi all,
I’m using freeRTOS v8 and I set:
configUSE_PREEMPTION 1
configUSE_TIME_SLICING 0
When I looked into the code I found this in xTaskIncrementTick():
if( pxTCB->uxPriority >= pxCurrentTCB->uxPriority )
Now imagine we have 2 tasks with the same priority. Task A is running a lengthy computation and task B is sleeping. When the sleep time of task B expires, it seems that it will wake up and then preempt task A. That’s what I deduce from the equal sign in the condition above.
What I’m trying to do is when 2 tasks with the same priority are ready to run we will start the first run it till the end of the task. the preemption that I want is only when there is a higher priority task or when there is an interrupt we will handle the interrupt and return to the task we left.
I assumed that by changing the condition above to:
if( pxTCB->uxPriority > pxCurrentTCB->uxPriority )
I will be able to do this but its doesn’t work…
Can you help me understand how the scheduler choose the next task to run when there are a few tasks with the highest priority in the ready state?
Thanks!
