groger57 wrote on Tuesday, February 02, 2016:
Running this:
FreeRTOS: 8.2.0
Device: STM32F4 Discovery board
I’m posting in this forum as I am hoping to find an answer to this issue. Although I have 1 year “paid” support with the Atollic software I have, they can’t seem to help me with this issue, I’m not sure that they understand what’s going on or just can’t be bothered to respond, so I hope someone here can help.
I have some very basic software. I set up the RTC, a couple of timers, an ADC single channel, and a FreeRTOS queue that is the ISR safe call. I need to make it clear that this software compiles and works perfectly well in IAR, and functions as it should, exactly.
Now, I’ve created a project in Atollic, and after getting through all the hoops and jumps with doing that, I have it compiling with no errors. Again, let me clarify the code is verbatim from the IAR, I just copied the source and header files over, using the same CMSIS libraries and FreeRTOS libraries.
After it starts running, it crashes. I have a breakpoint at vTaskStartScheduler(), but it never reaches there. Atollic chokes and breaks in HardFault_Handler in stm32f4xx_it.c I was told by Atollic support that it was enabling the RTC that was causing it. So, to prove this false, I commented out the call to the RTC initialization, and it was still crashing. Go figure.
I was also told that interrupts cannot be enabled before launching vTaskStartScheduler, but this has never caused a problem in IAR, or for that matter, in another Atollic program I have. I have read in this forum where Richard Barry responded to a similar issue regarding the enabling of peripheral interrupts and it seems that there is no issue with doing so.
Can anyone explain how it would work perfectly well using IAR, and not in Atollic? Is the GCC really that different (good or bad) compared to the IAR compiler? Or does this even have anything to do with FreeRTOS?
Thanks for any help or advice you can provide. (really need to get this functioning)
Gary
