spreetsingh wrote on Thursday, November 13, 2008:
I am trying to use Rowley 2368 port on a 2378 board. These processors are practically the same. Also, I am using the 20 pin Macraigor Wiggler to attach the PC to the board.
I have the following observations/questions:
1. The code compiles with the 2 warnings but no errors.
2. When I download the code, it downloads and is ready to run. Every time I try to run (Start Debug command from the interface), it erases the flash and reprograms it. Is this the correct behavior or I need to set some parameters so that it does not program the device every time ?
3. I assume that the code is doing something as I see the Green Led on the status bar flashing. However, I don’t see anything on the LED display or on the Debug I/O terminal window of the Rowley IDE.
I expected to see FreeRtos.org and pass/ fail messages on led
Am I missing something. Normally on other boards (MCB 2130 ) I can see the messages on the I/o window as expected.
Any one with any suggestions
Regards
Spreet
