nobody wrote on Thursday, July 13, 2006:
>We decided to merge from the commandline gcc to
>rowley 1.6 build 2. We disabled optimization until we
>get build 3. And we made a wiggler clone j-tag debugger.
>We stripped freertos to just a led blinker.
… and this works ok with the command line build?
>But we get crashes from rowley at the moment we step
>over a xtaskcreate line.
Can you step into xTaskCreate() and see where the crash is occurring? This function attempts to allocate memory, maybe there is a byte alilgnment issue in the heap?
>And if we set a breakpoint after the init
>and just before it is in normal operation it wil work.
>But when it is in normal operation and we want to pause
>the session it also crashes.
>We would like to know if this is caused by freertos because it can’t
>be debugged like this. What possebilties are there to bedug the sources by
>j-tag and how.
Does the debugger work with projects that don’t use FreeRTOS.org? It sounds like you are getting crashes before the kernel starts (xTaskCreate()), so I suspect it is not a FreeRTOS.org issue but a setup issue. I have never had a problem like this with Rowley, but I have only used CrossWorks with J-Link and CrossConnect JTAG interfaces, not wigglers.
I think you need to step into xTaskCreate() to see where the crash occurrs. This will provide a big clue as to what the problem is.
Are you calling main() in Supervisor mode? There is a definition in Rowley to do this (look at the lwIP project file that uses CrossWorks in the FreeRTOS.org download). Also are you setting up the Supervisor and IRQ mode stacks? Again you can see how this is done from the other CrossWorks examples in the download.
