nobody wrote on Sunday, May 06, 2007:
Someone has realized the porting on H8S/2633 of the Renesas?
rtel wrote on Tuesday, May 08, 2007:
The H8S port was tested on an 2329. If the 2633 has the same core then the porting effort should be minimal - maybe even just using a different linker file for the different memory.
Note that the 2633 has less RAM than the 2329 so you would have to reduce the heap size too - configMINIMAL_STACK_SIZE in FreeRTOSConfig.h header file.
