Hello, I will a start a new project using a LPC2129. I have tested the keil port, but I would prefer to start working with the RealView Development system. Does somebody know if this port is avalaible anywhere?
I have a project for the SAM7 that uses the RealView copiler with the Keil IDE. The SAM7 is also an ARM7 based processor so the modifications required are minimal to get it to work on the LPC2000. Hopefully also changing from the Keil to ARM IDE would be straight forward, although I’m not familiar with RealView. Send me an email to r [_dot_] barry [_at_] freertos.org if you would like a copy. It might be a starting point if nothing else.
