I am studying freertos to use in my project with PIC32MX.
I have newbie question:
how to do that after interupt i want run any task i want?
I have an interrupt from a hardware and i want just right after that interrupt to run specified task.
I know i can do that with semaphore, mutex, queue, but… it has to wait to timer tick and i want that task to run just after ISR routine has ended its job.
Is it possible to run specified task after ISR?
Read the “Configuration and Usage” section on the following page, in particular, the “Interrupt service routines” sub section. Note the use of the portEND_SWITCHING_ISR() macro. There are also examples in the PIC32 demo of the main FreeRTOS download and in the PIC32 edition of the FreeRTOS tutorial book.
Thanx for answer.
I just have written interrupt implementation of i2c and i have touchscreen controller interrupt driven. i must communicate with chip with interrupt driven state machine using i2c which is interrupt driven too:) it would be easier if interrupt could be interrupted:) but thanx, after interrupt from chip i can give control to common task in not interrupt state that can be interrupted:)
