keesdeboer wrote on Monday, August 20, 2018:
I’ve been stuck on a problem and I am a little bit clueless.
I’m using a PIC32MX, FREERTOS version 9.0, MPlabX IDE v 5.00 and the XC32 compiler version 1.44.
I’ve got a system with two interrupts, all implemented the RTOS style. RTOS wrapper, and very short. At the end of each interrupt, I preform the function portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
The two interrupt sources are one UART serial input and a pulse detect (I’m using a CCP input for that). Both interrupts gives a semaphore (of course with the FromISR after the function names). Two separate tasks takes the semaphore, read the byte from the UART or the pulse will be counted. The UART is continuously communicating with a speed of 9600bps and the pulses have a frequency of 4000 Hz. The Tickrate of the system is 1000 Hz. The UART interrupt has priority 3, the Pulse interrupt has priority 2. The configMAX_SYSCALL_INTERRUPT_PRIORITY is set to 7.
But after a while something annoying happens. The DelayedTaskList becomes empty, resulting in one active running task: the Idle task. Every other task comes in the ready state but the tasks won’t become active. The PIC32 is still running because interrupts keep firing. But the application itself runs only on FREERTOS so the application itself isn’t running. When not applying the pulses OR the UART bytes, this problem won’t occur.
To see something more, I’m using Percepio to view what’s happening. This problem only occurs when both interrupts fired at nearly the same time. The UART is first, giving a semaphore. But before the semaphore could be taken by the corresponding task, the pulse interrupt fires, also giving a semaphore. Both interrupt functions are very short, emptying a buffer, giving a semaphore (FromISR) and both end with the function portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );.
If I not end the interrupt function with the portEND_SWITCHING_ISR( xHigherPriorityTaskWoken ), everything goes well and the system keeps running without problems.
Long story so far, but here is the real question: What happens if the portEND_SWITCHING_ISR( xHigherPriorityTaskWoken ) function is running, preforming a taskYield and at that moment, an another Interrupt fires and also performs a taskYield. I think this is the reason my FREERTOS stops running active tasks, resulting in an empty DelayedTaskList. But I’m not the FREERTOS designer, so I could be wrong. But if I’m right, what can I do about it. Just never let the scheduled Yield after a interrupt and let the Idle task preform the yield (configIDLE_SHOULD_YIELD = 1)?
Thanks in advance,
Kees
