Hi Richard,
I started to play with FreeRTOS integrated in J.Wren’s LPC2148 package, recently. I was really amazed by the large scope of the package and by magnitude of work you put into RTOS itself.
In my application I wanted to check if a given queue is empty, but I couldn’t find such a function in your API. I found out that in revision 4.5.0 (mine is older 4.4.0) you introduced xQueuePeek and it can be used as a test whether queue is empty.
Why QueueLenth(aQueue) and IsQueueEmpty(aQueue) are not present in API ?
I also want to use the trace facility, but I can not localize tracecon.exe utility.
