nobody wrote on Saturday, September 16, 2006:
it would be nice add to queue.h xQUEUE structure definition or more function. My need now is using pxQueue->uxMessagesWaiting from ISR…
Janus
Janus
nobody wrote on Sunday, September 17, 2006:
The data type is deliberately hidden to prevent direct access. This enables the queue implementation to change without effecting application code.
For your particular needs you could add a simple get function (without the critical sections so it can be used from the ISR), or move the queue definition to the header file.
yes, I’ve done:
unsigned portBASE_TYPE uxQueueMessagesWaitingFromISR( xQueueHandle pxQueue ) // JU
return pxQueue->uxMessagesWaiting;
but it would be nice to be compatible with original the OS…
best regards
Janusz
