bob
(bob)
April 16, 2021, 5:24am
1
hello there I’ve been trying to learn how to stop a software timer in an ISR of a pushbutton but I cant seem to figure it out. Here is the code I’ve been trying to solve. As you can see my software timer, task1 and task 2 are all working. Any advice on how to make my pushbutton stop the software timer and print a message.
#include <assert.h>
#include <stdio.h>
#include <string.h>
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "timers.h"
#include "semphr.h"
#include "fsl_device_registers.h"
#include "fsl_debug_console.h"
#include "board.h"
#include "peripherals.h"
#include "pin_mux.h"
#include "clock_config.h"
#define SW_TIMER_PERIOD_MS (2000 / portTICK_PERIOD_MS)
#define Task1_PRIORITY (tskIDLE_PRIORITY + 1)
#define Task2_PRIORITY (tskIDLE_PRIORITY + 2)
static void Task1(void *pvParameters);
static void Task2(void *pvParameters);
/* The callback function. */
static void SwTimerCallback(TimerHandle_t xTimer);
volatile bool SW2btn_press = false;
void delay(void)
uint32_t i = 500000U; /*this count wastes appr. 0.5 seconds*/
while (i--)
__NOP(); /* No Operation instr. wastes one clock cycle. Note the double score prefix*/
void BOARD_SW2_IRQHANDLER(void) {
uint32_t flags = GPIO_PortGetInterruptFlags(BOARD_SW2_GPIO);
GPIO_PortClearInterruptFlags(BOARD_SW2_GPIO, flags);
SW2btn_press = true;
xTimerStopFromISR( xTimerHandle, &xHigherPriorityTaskWoken );
int main(void) {
TimerHandle_t SwTimerHandle = NULL;
/* Init board hardware. */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitBootPeripherals();
BOARD_InitDebugConsole();
SystemCoreClockUpdate();
xSemaphore_Task1 = xSemaphoreCreateBinary();
xSemaphore_Task2 = xSemaphoreCreateBinary();
/* Create the software timer. */
SwTimerHandle = xTimerCreate("SwTimer",SW_TIMER_PERIOD_MS,pdTRUE,0,SwTimerCallback);
if (xTaskCreate(Task1, "TASK1", configMINIMAL_STACK_SIZE + 128, NULL, Task1_PRIORITY, NULL) != pdPASS)
PRINTF("Task creation failed!.\r\n");
while (1)
if (xTaskCreate(Task2, "TASK2", configMINIMAL_STACK_SIZE + 128, NULL, Task2_PRIORITY, NULL) != pdPASS)
while (1)
/* Start timer. */
xTimerStart(SwTimerHandle, 0);
/* Start scheduling. */
vTaskStartScheduler();
for (;;)
PRINTF("ABC\n\n");
xSemaphoreGiveFromISR(xSemaphore_Task1, &xHigherPriorityTaskWoken);
for(;;)
xSemaphoreTake(xSemaphore_Task1, portMAX_DELAY);
PRINTF("task 1\n\n");
xSemaphoreGive(xSemaphore_Task2);
void Task2(void *pvParameters){
for(;;)
xSemaphoreTake(xSemaphore_Task2, portMAX_DELAY);
PRINTF("task 2\n\n");
vTaskDelay(pdMS_TO_TICKS(1000));
/*output
ABC
task 1
task 2
next i want to press sw2 an interupt will occur. When the interupt occurs it will stop the software timer and print a message
hs2
(Hartmut Schaefer)
April 16, 2021, 7:28am
2
Aside from better using vTaskDelay instead of your delay function what’s the problem ? What is not working as expected or is there a crash ?
Also you ally should define configASSERT and also enable stack overflow checking for development/debugging.
Hint: Please enclose code blocks by 3 tildas (~~~) or backticks (```) for better readability.
bob
(bob)
April 16, 2021, 7:53am
3
when i press my pushbutton(sw2) the software timer should stop and display a message, but nothing happens when i press the button
hs2
(Hartmut Schaefer)
April 16, 2021, 8:12am
4
Oops - SwTimerCallback is a task level callback. It’s NOT called from ISR context.
FreeRTOS timers are software timers managed by a separate task.
Just use xSemaphoreGive in the timer callback. Also try to keep the timer callbacks short (i.e. avoid lengthy operations like debug output) because otherwise they might delay other timers maybe running.
BOARD_SW2_IRQHANDLER seems incomplete. Where is xHigherPriorityTaskWoken defined (and the corresponding portYIELD_FROM_ISR is missing).
Where is the code for intended output on timer stop ?
A common pattern for handling interrupts is signaling a task about the event and do the necessary post-processing there. This also applies to ‘printf’ family functions because they normally can’t be used in ISRs.
bob
(bob)
April 16, 2021, 8:49am
5
i am confused on how i would stop the software timer in my button isr and display a message. Is there a certain line of code i should be using to do this
hs2
(Hartmut Schaefer)
April 16, 2021, 9:12am
6
Well, you correctly stop the timer with xTimerStopFromISR.
I’d append portYIELD_FROM_ISR( xHigherPriorityTaskWoken );
What about adding a 3rd task (I guess it’s just an test application you’re writing) just waiting for another semaphore signaled in addition by the button ISR and then printing something ?
bob
(bob)
April 16, 2021, 9:16am
7
i will add a third task. the problem is i added a print statement to the button isr and the message is not being displayed. If i’m not mistaken by me stopping the software timer and pressing sw2 an interrupt should have been triggered and the message displayed
hs2
(Hartmut Schaefer)
April 16, 2021, 10:30am
8
I guess the PRINTF in the ISR crashed the app. With a debugger your live will be a lot easier. Set a breakpoint in the ISR and simply setup trough the code.
And: Better post exactly the code you’re asking about. The posted ISR code is incomplete.
How would you use the function “xTimerStopFromISR”, to stop the software timer?
hs2
(Hartmut Schaefer)
April 20, 2021, 9:40pm
10
#include <assert.h>
#include <stdio.h>
#include <string.h>
/* Kernel includes. */
#include "task.h"
#include "queue.h"
#include "timers.h"
#include "semphr.h"
/* Freescale includes. */
#include "board.h"
TaskHandle_t TaskHandle_1;
TaskHandle_t TaskHandle_2;
TaskHandle_t TaskHandle_3;
TaskHandle_t TaskHandle_4;
/* The software timer period. */
#define TaskA_PRIORITY (tskIDLE_PRIORITY + 1)
#define TaskB_PRIORITY (tskIDLE_PRIORITY + 1)
#define TaskC_PRIORITY (tskIDLE_PRIORITY + 1)
#define TaskD_PRIORITY (tskIDLE_PRIORITY + 1)
BaseType_t xHigherPriorityTaskWoken = pdTRUE;
volatile bool taskStop = false;
volatile bool taskReset = false;
SemaphoreHandle_t xSemaphore_TaskA;
SemaphoreHandle_t xSemaphore_TaskB;
SemaphoreHandle_t xSemaphore_TaskC;
SemaphoreHandle_t xSemaphore_TaskD;
TickType_t SwTimerHandle;
static void TaskA(void *pvParameters);
static void TaskB(void *pvParameters);
static void TaskC(void *pvParameters);
static void TaskD(void *pvParameters);
uint32_t flags = GPIO_PortGetInterruptFlags(BOARD_SW2_GPIO); /*get triggered interrupt flag*/
GPIO_PortClearInterruptFlags(BOARD_SW2_GPIO, flags); /*clear triggered interrupt flag*/
taskStop = true;
PRINTF("\r\nSW2 ISR –EMERGENCY – all operations are suspended!\r\n");
void BOARD_SW3_IRQHANDLER(void)
uint32_t flags = GPIO_PortGetInterruptFlags(BOARD_SW3_GPIO); /*get triggered interrupt flag*/
GPIO_PortClearInterruptFlags(BOARD_SW3_GPIO, flags); /*clear triggered interrupt flag*/
taskReset = true;
PRINTF("\r\nSW3 -NORMALsystem operation is resuming...\r\n");
int main(void) {
xSemaphore_TaskA = xSemaphoreCreateBinary();
xSemaphore_TaskB = xSemaphoreCreateBinary();
xSemaphore_TaskC = xSemaphoreCreateBinary();
xSemaphore_TaskD = xSemaphoreCreateBinary();
SwTimerHandle = xTimerCreate("SwTimer", /* Text name. */
SW_TIMER_PERIOD_MS, /* Timer period. */
pdTRUE, /* Enable auto reload. */
0, /* ID is not used. */
SwTimerCallback); /* The callback function. */
if (xTaskCreate(TaskA, "TASKA", configMINIMAL_STACK_SIZE + 128, NULL, TaskA_PRIORITY, &TaskHandle_1) != pdPASS)
while (1)
if (xTaskCreate(TaskB, "TASKB", configMINIMAL_STACK_SIZE + 128, NULL, TaskB_PRIORITY, &TaskHandle_2) != pdPASS)
while (1)
if (xTaskCreate(TaskC, "TASKC", configMINIMAL_STACK_SIZE + 128, NULL, TaskC_PRIORITY, &TaskHandle_3) != pdPASS)
while (1)
if (xTaskCreate(TaskD, "TASKD", configMINIMAL_STACK_SIZE + 128, NULL, TaskD_PRIORITY, &TaskHandle_4) != pdPASS)
while (1)
/* Start timer. */
for (;;)
* @brief Software timer callback.
PRINTF("\r\nSoftware Timer ISR -Sensors are read");
xSemaphoreGiveFromISR(xSemaphore_TaskA, &xHigherPriorityTaskWoken);
for(;;)
LED_GREEN_ON();
LED_BLUE_OFF();
LED_RED_OFF();
xSemaphoreTake(xSemaphore_TaskA, portMAX_DELAY);
PRINTF("\nTask1\n");
xSemaphoreGive(xSemaphore_TaskB);
for(;;)
xSemaphoreTake(xSemaphore_TaskB, portMAX_DELAY);
PRINTF("Task2\n");
if(taskStop == true)
xSemaphoreGive(xSemaphore_TaskC);
taskStop = false;
for(;;)
xSemaphoreTake(xSemaphore_TaskC, portMAX_DELAY);
vTaskSuspend(TaskHandle_1);
vTaskSuspend(TaskHandle_2);
LED_GREEN_TOGGLE();
LED_RED_ON();
PRINTF("\r\nTask3-EMERGENCY protocol is being executed...\n");
PRINTF("RED LIGHT and SOUND ALARM are ON\n");
PRINTF("Press button SW3 to clear the system and reboot...\n");
xTimerStopFromISR( SwTimerHandle, &xHigherPriorityTaskWoken );
if (taskReset == true)
xSemaphoreGive(xSemaphore_TaskD);
taskReset = false;
for(;;)
xSemaphoreTake(xSemaphore_TaskD, portMAX_DELAY);
xTimerResetFromISR( SwTimerHandle, &xHigherPriorityTaskWoken );
vTaskResume(TaskHandle_1);
vTaskResume(TaskHandle_2);
This stops the timer but it doesn’t resume the timer when sw3 is pushed; is there something wrong with the code?
aggarg
(Gaurav Aggarwal)
April 22, 2021, 4:57am
12
There are couple of things you need to fix in this code:
Do no call PRINTF from ISR.
Software timer callbacks are executed in the timer task’s context - you do not need FromISR APIs there:
Do not call FromISR APIs from tasks:
