gerhardkreuzer wrote on Tuesday, February 02, 2016:
where can I find this file on FreeRTOS page ??
Thanks a lot
With best regards
Gerhard
Thanks a lot
With best regards
Gerhard
rtel wrote on Tuesday, February 02, 2016:
Did you search the FreeRTOS distribution for the file? I think you will find about 40 different copies ;o)
However, the most complete version is found in the FreeRTOS labs download - again just search the directory structure for the file.
… downloaded 160112_FreeRTOS_Labs.zip, check each dir, nothing found …
heinbali01 wrote on Tuesday, February 02, 2016:
In the current labs distribution it is called::
Common\Utilities\printf-stdarg.c
The latest version is quite compatible with GNU’s [v][s][n][printf except that it doesn’t recognise floating point parameters.
You find it in this file
