Each port has its own portmacro.h file and each project must ensure it includes the correct one. Look in source/include/portable.h to see how this is done. Normally you define a macro in the project to tell the compiler which portmacro.h to include. The alternative is to simply ensure the correct include path is within your project.
But unforunately this is not the problem. If I substitute portSTACK_TYPE with "unsigned long" in port.c to let the function look as follows, the same error messages "declaration syntax error" and "undefined identifier ´pxTopOfStack´ occur:
unsigned long *pxPortInitialiseStack( unsigned long *pxTopOfStack, pdTASK_CODE pxCode, void *pvParameters )
portmacro.h is already included, too.
Am I not allowed to use the type unsigned long in this case?
Thats nearly impossible. I made a project build in the codewarrior IDE and edit the files straight from there. Do you think it´s more problem of the FreeRTOS port or the compiler?
