Hi all,
we inserted ‘base’ FreeRTOS in our projects and everything work fine.
Now I need to add the Ethernet support and I added the TCP package.
For a compile test I onlt added the FreeRTOS_IP.c file: it generates a lot of errors.
I dig them until I guess to have found the root problem: in list.h file some functions are defined with the constant PRIVILEGED_FUNCTION.
This one generates the error:
FreeRTOS\include/list.h:386:6: error: old-style parameter declarations in prototyped function definition
and all the other errors.
I found the definition of this constant in mpu_wrappers.h: this is included by portable.h file that is included by FreeRTOS.h file.
My guess the problem is due to the late inclusion of FreeRTOS.h in the FreeRTOS_IP.c file: the previous inclusions of the .h files do not see the constant definitions and produce the error.
If I move the FreeRTOS.h before the FreeRTOS_.h files I get the error:
include/tcp/FreeRTOS_ARP.h:77:2: error: unknown type name 'MACAddress_t'
MACAddress_t xMACAddress; /* The MAC address of an ARP cache entry. */
but this type is defined in the FreeRTOS_IP.h that’s included after the FreeRTOS_APR.h.
I’m not sure what would happen if you only built one source file. I
would recommend opening one of the example projects provided in the +TCP
(Labs) download to see the files that are being built. That can be done
using the Win32 example, which only requires the free community edition
of Visual Studio. Once you have the example project opened in Visual
Studio it should build without any problems, then you can use it as a
reference as to which files to build and which include paths to set.
I’m very sorry.
I compared my files against the original ones and I discovered that my colleague changed them
The files are perfectly compilable for an LPC1778.
Sorry again.
By the way, is there a NetworkInterface.c file available for NXP LPC1778 ?
I found a version from a newsletter’s subscriber but it include some files not included on my sdk (by NXP):
