Sergei
January 7, 2022, 2:23am
1
if a task is in a busy loop, a higher-priority task does not preempt it even if configUSE_PREEMPTION == 1, why?
I expected a real-time RTOS with priority preemption to suspend any running task if a higher priority task is on the task ready list. FreeRTOS only does it for timeslicing at the same priority level. This seems like a bug to me, but maybe I misunderstand something. Relevant code in xTaskIncrementTick():
#if ( ( configUSE_PREEMPTION == 1 ) && ( configUSE_TIME_SLICING == 1 ) )
if( listCURRENT_LIST_LENGTH( &( pxReadyTasksLists[ pxCurrentTCB->uxPriority ] ) ) > ( UBaseType_t ) 1 )
xSwitchRequired = pdTRUE;
mtCOVERAGE_TEST_MARKER();
#endif /* ( ( configUSE_PREEMPTION == 1 ) && ( configUSE_TIME_SLICING == 1 ) ) */
only checks the same priority, and
#if ( configUSE_PREEMPTION == 1 )
if( xYieldPending != pdFALSE )
#endif /* configUSE_PREEMPTION */
only checks for yield pending.
A workaround is to do a periodic yield, but that becomes cooperative multitasking, not true priority preemption.
aggarg
(Gaurav Aggarwal)
January 7, 2022, 4:19am
2
Let me try to understand your case. You have 2 tasks something like the following:
void LowPriorityTask( void * param )
for(;;)
/* Keep Looping. */
void HighPriorityTask( void * param )
for(;;)
/* Keep Looping. */
And you are saying that the low priority task keeps running? That would be a very fundamental bug. Which platform are you using? Can you share your code snippet?
aggarg
(Gaurav Aggarwal)
January 7, 2022, 4:24am
3
I quickly verified it on a STM32 platform and it works as expected i.e. high priority task keeps running and low priority task never runs.
Sergei
January 7, 2022, 4:30am
4
It’s a bit more subtle than that. Start a high-priority task, and a low priority task. The high priority task will run, as expected. Then have it yield, or wait for a short delay with vTaskDelay(), so that the low-priority task gets to busy-loop. The high priority task never gets to run again. Hope this makes sense.
It’s not visible in your example because on task creation the ready list is explicitly checked, unlike in xTaskIncrementTick().
aggarg
(Gaurav Aggarwal)
January 7, 2022, 4:42am
5
I changed my code to the following:
static void HighPriorityTask( void *param )
( void ) param;
for( ;; )
vTaskDelay( pdMS_TO_TICKS( 100 ) );
static void LowPriorityTask( void *param )
( void ) param;
for(;;)
It still works as expected - I see that high priority task is running periodically.
Sergei
January 7, 2022, 7:33am
6
trying to reply, but the system tells me I’m not allowed to post links, even though there are no links in my reply
Sergei
January 7, 2022, 7:51am
7
Interesting, what you are showing makes sense, but this is not at all what I see:
void high_task(void *p)
int i = 1;
while (true)
printf("high %u\n", i++);
void low_task(void *p)
int i = 1;
TaskHandle_t taskhandle;
xTaskCreate(high_task, "high", 1000, NULL, 1, &taskhandle);
vTaskDelay( pdMS_TO_TICKS( 200 ) );
while (true)
printf("low %u\n", i++);
void main()
xTaskCreate(low_task, "low", 1000, NULL, 2, &taskhandle);
vTaskStartScheduler();
for (;;)
Sergei
8
Output:
high 1
high 2
low 1
low 2
low 3
low 4
low 5
low 6
low 7
low 8
low 9
low 10
Sergei
January 7, 2022, 7:52am
9
For reference, this is the OS version: FreeRTOS Kernel V10.0.1
and it runs on an NXP LPC MCU, bundled and built with MCUXpresso. Maybe that can clarify things.
aggarg
(Gaurav Aggarwal)
January 7, 2022, 9:14am
10
printf might not be thread safe. Can you remove printf and check by placing breakpoint?
Sergei
January 7, 2022, 9:35am
11
Did that, the breakpoint in the high-priority task is never hit after the vTaskDelay() call in the low-priority task completes.
hs2
(Hartmut Schaefer)
January 7, 2022, 9:37am
12
Seems you set the wrong priorities. The low_task is created with a higher (2) prio than the high_task (1), right ?
Sergei
January 7, 2022, 9:38am
13
lower numbers are higher priorities, as I understand it.
hs2
(Hartmut Schaefer)
January 7, 2022, 9:49am
14
No. See the docs RTOS task priorities in FreeRTOS for pre-emptive and co-operative real time operation
Task priorities are let’s say logical priorities. Low number - low priority.
Don’t get confused with low level interrupt priorities on ARM Cortex-M MCUs where it’s reversed.
There are a number of related posts in the forum like this one:
Sergei
January 7, 2022, 7:38pm
15
Confirmed, was my misreading of the direction of priorities. Thanks!
