I am still getting error, I have downloaded the latest file. I didn’t find *&xSchedulerOriginalSignalMask, but still showing that error.
Please try to provide some solution @rowbearto
error: incompatible type for argument 3 of ‘pthread_sigmask’
*&xSchedulerOriginalSignalMask );
In file included from /usr/include/signal.h:359:0,
from /home/jmayank/Desktop/FreeRTOSv202012.00-LTS/FreeRTOSv202012.00/FreeRTOS/Source/portable/ThirdParty/GCC/Posix/port.c:53:
/usr/include/x86_64-linux-gnu/bits/sigthread.h:31:12: note: expected ‘__sigset_t * restrict {aka struct * restrict}’ but argument is of type ‘sigset_t {aka struct }’
extern int pthread_sigmask (int __how,
Hey @jmayank, you’re completely right that the 2020-12 version has this bug. Thank you for bringing this to our attention. We’re discussion solutions now but hope to have a patch, or something similar out soon.
As a workaround, you can simply remove the * to make the parameter &xSchedulerOriginalSignalMask like what was done here. This should get your build working.
Edit: previous write up was incorrect so I removed it.
@jmayank Got done talking with my team (after learning a bit regarding our LTS versions). We won’t be patching this in the 2020-12 LTS release for a couple reasons:
The workaround is simple to implement (remove the erroneous ‘*’ or use a newer LTS version) but the patch would have far reaching impact for other LTS users of this version.
The POSIX port is a third party port and doesn’t see production use since it’s for demonstration/experimentation.
I hope this justification gives some transparency into our thought process. Best of luck on your development and feel free to reach out if you face further issues.
