I would like to create an emulator for an existing product, and have chosen CentOS 8.3 as the emulator host (running in a Docker image, FWIW). I downloaded FreeRTOSv202104.00 and when I run ‘make’ on the Demo/Posix_GCC, make fails with
/wxsat/FreeRTOSv202104.00/FreeRTOS/Source/portable/ThirdParty/GCC/Posix/port.c: In function 'prvSetupSignalsAndSchedulerPolicy':
/wxsat/FreeRTOSv202104.00/FreeRTOS/Source/portable/ThirdParty/GCC/Posix/port.c:528:28: error: incompatible type for argument 3 of 'pthread_sigmask'
*&xSchedulerOriginalSignalMask );
In file included from /usr/include/signal.h:359,
from /wxsat/FreeRTOSv202104.00/FreeRTOS/Source/portable/ThirdParty/GCC/Posix/port.c:53:
/usr/include/bits/sigthread.h:33:31: note: expected '__sigset_t * restrict' {aka 'struct <anonymous> * restrict'} but argument is of type 'sigset_t' {aka 'struct <anonymous>'}
__sigset_t *__restrict __oldmask)__THROW;
make: *** [Makefile:79: build//wxsat/FreeRTOSv202104.00/FreeRTOS/Source/portable/ThirdParty/GCC/Posix/port.o] Error 1
While I am digging into this, I wonder if it’s a known problem with a known solution?
I have gcc v8.4.1, make 4.2.1, and libpcap-devel 1.9.1 (which the startup documentation says should be satisfactory).
