I have now integrated FreeRTOS in the NIOS 2 ecosystem provided by Intel, based on Eclipse (Mars), but the compilation faild with strange errors.
The port I used is based on FreeRTOS 7. I personally have FreeRTOS 8 somewhere hanging around but I tried the current version.
Is this a problem?
I tried to find V7 on the web page, but no chance.
My error? BaseType_t is undefined …
Hi Gustav,
want to post a reply to myself and now found your reply.
You were right, in my portmacro.h which I get, this definitions were absent.
Why?
Ok, not a big deal for now, youst copied it in and, lot better.
But I have another strange problem. I hope I can insert a screen shot here.
There is a line ‘#define portBASE_TYPE long’ and I get the error ‘Missing binary operator before token long’.
I am not that C language guru, but I can’t find any strange syntax in this line.
Two lines above there is a similar definithion, no error.
This lines were originally and untouched, but maybe, the guy making the port did something special.
Is there any explaination, why the typedefs for BaseType_t were missing? Is this a versioning problem?
Where there other files affacted?
Thanks for helping!!!
I try to upload the screenshot now, you will see if I am successful or not.
I get the a port from freertos.org and another one from a company (about 8 years old). I first struggle to integrate it into the Eclipse environment I get from Intel for the NIOS 2 processor. The port from freertos.org is for older and now incompatible tool chain, the other example fits better and so I am able to do integration.
I also will shar this work if I am successful.
Here my experiments. I changed ‘long’ to the type ‘alt_32’, this is the type the software from intel is using, same problem. I restarted Eclipse, same problem, I moved the line elswhere, same problem.
I getting frustrated now.
because configMAX_PRIORITIES is type cast. The preprocessor’s expression evaluator wants simple numeric literals only, like 5 or even 5UL etc., but not (int) 5 or the like.
In FreeRTOSConfig.h, you will probably have to change configMAX_PRIORITIES to:
#define configMAX_PRIORITIES (OS_MAX_PRIORITIES)
assuming as Gaurav mentioned that the #define for OS_MAX_PRIORITIES is a simple numeric literal.
the file stack_macros.h were missing, because it appears at a later version than the port/example was made.
There is a script to provide to the Eclipse eco system which runs when the BSP (board support package) which infact is a softcore support package is prepared.
During this process, all files from a list were copied from a folder called ‘components’ to the project folder for use with the app.
So you can made changes to the files in the IDE, but after generating a new BSP … but ok, is as is.
After extending this script and copying stack_macros.h I get a correct setup and …
… it compiles !!!
So, I have a syntactically correct FreeRTOS distribution, now lets see if it is semantical correct too.
Open questions for now:
How should I deal with the cast problems in FreeRTOSConfig.h, or is this a file I have to alter to fullfill my compilers needs? (And I don’t mean only the numbers used here).
Thanks all for helping so far. I hope the port.c file and some other points arn’t that bad.
here another ‘problem’, maybe caused by versioning:
void vPortSysTickHandler( void )
// only make ticks if the scheduler has been started.
if ( xTaskGetSchedulerState() != taskSCHEDULER_NOT_STARTED )
// Increment the Kernel Tick.
vTaskIncrementTick();
// If using preemption, also force a context switch.
#if configUSE_PREEMPTION == 1
vTaskSwitchContext();
‘vTaskIncrementTick();’ is not known (any more), and the compiler ask me, if I want to use ‘xTaskIncrementTick();’ instead.
It’s probably a solution, not a hack. You could go look at all the uses of configMAX_PRIORITIES to determine the impact of the casting, but it’s probably not important for this particular symbol.
Yes, you can “upgrade” to xTaskIncrementTick() and then use its return value to conditionally call vTaskSwitchContext().
And be sure to look over the link Richard sent about upgrading from v7.
I read the linked document, its most about new type names (xx_t) now, so this is solved quite good.
Unfortunately, the eco system from Intel wants to create two projects, one app and one bsp (board support package). Ok, but the app I get from the port is something very complicated, looks like a test suite for all features of FreeRTOS and something more.
I will try to set up some simpler, but I first have to find out how this scripts working. Awful system.
Problem is, that this two projects should be linked together, but no info how to do.
Have now the FreeRTOS kernel, compiles fine and a second project, the app, with an empty main and the kernel referenced this main (some init and startup code there), but …
Looks like alt_malloc_lock.c and alt_env_lock.c use vTaskDelay(), so you’ll want to define INCLUDE_vTaskDelay to 1 in FreeRTOSConfig.h.
And it looks like your FreeRTOSConfig.h has configCHECK_FOR_STACK_OVERFLOW defined to a nonzero value. That’s good. You’ll need to provide a vApplicationStackOverflowHook() function to handle stack overflow.
