portYIELD_FROM_ISR
dgheyl wrote on Friday, June 08, 2007:
There are some examples in the documentation that use a macro named portYIELD_FROM_ISR.  I can’t find this macro anywhere.  Can someone explain what I’m doing wrong?
Regards,
Dave
embeddedc wrote on Friday, June 08, 2007:
It depends on which port you are using.  Normally it is defined in portmacro.h.  Sometimes in portasm.s.  These files are in the FreeRTOS\Source\portable\[compiler]\[processor] folder.
OK, so it’s not defined for the AVR (or most other ports).  Does that mean I can just use the taskYield macro from the ISR?
Thanks,
Dave
Your best bet is to look at the sample serial port driver that comes with a demo for the port you are using.  There is one for each port.  Copy what ever that does.
