mattzz wrote on Monday, April 17, 2006:
I started to port FreeRTOS to the OpenRISC 1200.
I started putting things together based on the Microblaze port, wrote a Makefile and a first test but there is not much really working up to now. (I am currently getting into OpenRISC hacking with respect to exception handling, context saving/restoring and IRQ processing…)
A first release can be found here:
http://mattzz.dyndns.org/twiki/bin/view/Projects/PortingFreeRTOStoOpenRISC
With the help of some hands this kernel port should be really easy as there are basically only three files to edit (port.c, portmacro.h and
portasm.S).
Please contact me if you have some ideas or you simply want to help.
Best regards,
/Matthias
