system
(system)
May 28, 2009, 9:55am
1
aviasaf wrote on Thursday, May 28, 2009 :
hello all,
i have ported the freertos to at91sam7s512 base on at91sam7s256 porting i did before.
i develop under the IAR 5.2 and using freertos version is 511.
when the first task is called by the scheduler I got data abort and the program crash.
did any one deals with this kind of problem before?
maybe I miss some issue in the cstartup file ?
thanks in advance
Avi
system
(system)
May 28, 2009, 9:58am
2
davedoors wrote on Thursday, May 28, 2009 :
I think the only thing you would need to change would be the map file as the 512 has more flash and ram. Other than that I think the two devices are the same.
system
(system)
May 28, 2009, 10:22am
3
that’s what i did, still it is not working.
do you have an example of freertos application running on at91sam7s512?
if so, I will be glad to get this demo.
thanks
