I managed to sucsessfully port FreeRTOS to MSP430FG4618 using GCC+Eclipse cdt.
I could run the FlashTasks for 3 on board LCD Leds, checking if otherTasks are running+MathTest+ApplicationIdleHookNotStalling+CheckIfErrors, each task toggling a LED. I defined another task in main(), similar to CheckIfErrors, that toggles a led with mainNoError rate just for comparing the rate it toggles a LED, with mainErrorCheck rate.
I am using the small memory model(heap1.c in memoryManagement and including Minimal in Common folder).
But, i have a problem!
I cannot use more than 7 tasks a time, because i get a _stop_prog_exec() error, while debugging
So if i use just 2 LEDs in flash.c, i can use all the other 5 tasks, or i can use 3 LEDs toggling in flash.c, but i can’t use the task i defiined NoErrorCheck() in this case.
Could anyone tell me what is this _stop_prog_exec() error about? am i using all the available stack reserved in Minimal memory management model.
I have another question: I notice while debugging that it keeps running a task called _udivmod4 for a very long time interval.
I could get no description in FreeRTOS.org about that. does anyone know what is this about? Sometimes it gets stuck when i run the step mode debugging while it is in this udivmod4si.
i think you’re right. Iam probably running out of heap space. I will try to increase the configTOTALHEAPSIZE, because it is configured for the smaller F449 microcontroller.
But could you please give me a hint: how could i know exactly which is the maximum heapsize i can use for my microcontroller, is there any way i can figure that out, and what are the bad conseguences that could come out by increasing it?
thank you very much for your reply, and thank you very much for FreeRTOS, its a great work you have done, i liked a lot working with it. I would like to contribute. Could you please give me some hints, as soon as i have the final version of this port, what should i do for giving it to the community.
Were you able to get the FreeRTOS port to the msp430fg4618? I am having trouble configuring FreeRTOS to run on msp430fg4618. (Please see my post under “anne13”.) Any help/suggestions would be appreciated.
