Hi all,
I have been working with i.MX27 processor.I have using freeRTOS for my project and use STR91x processor as my base.I want to create a TCP/IP stack for my processor.My question is that,what are the files should be needed and where i can modify the code and in which files.Please anyone give solution for my questions…
Hi davedoor,
Thanks for your reply.Yes,the demo for STR91x in the FreeRTOS contains a TCP/IP example.I think that lwip and webserver directories are relates with TCP/IP buti don’t know,what are the files are portable and non portable.where i can start my process…
lwIP is ported to many architectures including PPC, DSPs, unix, etc. You only need to write a phy/mac driver for your system,
the rest will be same among all architectures.
