Hello to all, I recently started using an usb stick with Str91x.
I use the Rowley Crossworks as a tool of development, the original package of freeRTOS5 include a demo for IAR str91x however, someone can give me a version for Rowley CrossoWorks?
I want to run lwIP on my stick to test SNMP, can somebody help me?
I have an STR9 GCC port on record that I could send. This would give you a good head start as Rowley uses GCC. Send me an email to r _dot barry [at] freertos.org if you would like a copy.
Hi, I checked the files that have sent me but there is no lwIP
. On my stick usb STr91x works already FreeRTOS 5 with Rowley Crossworks, also works uIP.
I can’t able to use UDP so i wanted to try to put lwIP with FreeRTOS 5 since UDP works best in lwIP.
In the package distribution FreertOS there is already a demo for Str91x with lwIP however, is for IAR, since I use Rowley Crossworks I serve or a demo functioning of FreeRTOS + lwip for Rowley or instructions to convert the demo for IAR in demo Rowley.
