jtbr wrote on Thursday, March 16, 2017:
I’m trying to get FreeRTOS-Plus-TCP working on an Atmel SAM V71 (which has a cortex M7 and a KSZ8061RNBVA ethernet PHY). I started with a working FreeRTOS 8.2.3 using heap4, added Plus-TCP (r160919) using BufferAllocation2, and based my NetworkInterface.c upon the included Cortex M3/M4 example, while using the latest Atmel ASF drivers for the GMAC and ethernet_phy for my device.
This is producing a hard fault some time after the TCP tasks begin; it occurs whether or not there is a cable connected to the ethernet port. In either case, the vApplicationIPNetworkEventHook is correctly called with the eNetworkUp/Down event. And the GMAC_Handler interrupt handler is called at least once without apparent issues, when the cable is connected.
For debugging purposes, I have disabled all other tasks, and disabled the -Plus-Trace library and printfs via the serial UART. configASSERT, configCHECK_FOR_STACK_OVERFLOW (2), and configUSE_MALLOC_FAILED_HOOK are defined, but do not occur. configMAC_INTERRUPT_PRIORITY is configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY, which is 4. configLIBRARY_LOWEST_INTERRUPT_PRIORITY is 7 (configPRIO_BITS is 3). configUSE_PREEMPTION is 1, and configIDLE_SHOULD_YIELD is currently 0, as is configUSE_TICKLESS_IDLE So far as I know, the only interrupt registered is for the network interface (interrupt number 39 as defined in the GMAC driver).
I have seen the hard fault debugging advice here, but am having trouble making use of it. I have disabled ICache and DCache, TCM has never been enabled, and I set the DISDEFWBUF bit (SCnSCB->ACTLR |= 2;) to stop write buffering and prevent imprecise faults. I have confirmed that these are direct Hard faults, not MemManage, BusFault or UsageFaults, and are not imprecise (0xE000ED29 & 0x02 == 0).
However when I use the code on the linked page, I don’t seem to be getting useful information and am at a bit of a loss for how to debug this. When I first arrive in the HardFault_Handler, (0xe000ed04) & 0xFF , which should contain the interrupt number, is 3 (like I mentioned I thought there was only one interrupt, number 39). When I use the provided code to restore the registers, I get: r0=0, r1=0x20404e1c, r2=0x10000000, r3=0xe000ed04, r12=0x20404de4, lr=0x0040a41d, pc=0x20400004, psr=0x00000200. pc points to the DTCM section of memory rather than flash (which starts at 0x00400000), and is apparently not executable code; certainly I’m not able to put a breakpoint there. So I can’t determine the source of the hard faults.
I’m happy to share my current NetworkInterface.c code if it might help.
Many thanks for any help!
