Plus-TCP on SAMv71 hard fault debugging
jtbr wrote on Friday, April 07, 2017:
No, I only meant that I’m using the port code for 8.2.3 found under Source\portable\GCC\ARM_CM7\r0p1. So if the bug fix is not there then it sounds like it’s best that I switch to v9.
rtel wrote on Friday, April 07, 2017:
Oh - maybe I am mistaken then, if that directory is in V8.2.3 then it is
also good to use. I thought it didn’t get added until V9.
Even more puzzling then. Because I’ve just updated to 9.0.0 and at first inspection, the problem appears to go away! I’ve only tested this simplest case that always caused a Hard Fault, but that’s already something!
jtbr wrote on Tuesday, April 11, 2017:
Just wanted to confirm that using FreeRTOS 9.0.0 does indeed fix the faults. I’m now debugging functionality of the driver. Thanks for the help!
