I can not ping my virtual visual studio simulator from the same pc. I can only test the Windows simulation +TCP project from a different laptop, or from an external embedded device.
Ping is working properly from a different PC to my FreeRTOS windows simulator. But why it is not working from same PC?
I there any way or some settings in windows where I can ping to my virtual simulator from the same pc or host?
Do you have an Ethernet cable plugged in to the network card you are selecting with the configNETWORK_INTERFACE_TO_USE setting? Unfortunately it has to be Ethernet, not Wi-Fi.
Are the IP addresses and netmask values in the FreeRTOS executable, the host PC on which the executable is running, and the network the PC is connected to all compatible with each other (are all on the same subnet)?
