I have just gone through the exercise of getting the FreeRTOS_Plus_TCP_and_FAT demo working, but only after stumbling on some posts from 2018 that suggested attempts to access the RTOSDemo application need to be made from a different computer on the same network. Yet all of the documentation (tutorial steps) either state or imply that ping, and ftp access using FileZilla should work on the same computer.
(1) if that is truly possible, could someone who knows how to make it work update the tutorial pages; or
(2) if in fact access needs to be from a different computer than the one running RTOSDemo, then please update the documentation accordingly.
After succesfully building the project in VisualStudo 2019 with no compilation or build errors out of the box, following what appeared to be accurate step by step instructions (other than the console output listing network interfaces when I ran the demo looked nothing like the image in the instructions), it was extremely frustrating to then kill 2 hours trying to understand why I couldn’t ping the RTOSDemo.
The development environment is VS2019, W10 Pro, plenty of memory and disc.
Jack
4. rpcap://\Device\NPF_{21A5AEFB-730B-42E6-9434-B807F70A11BC} Network adapter 'Realtek PCIe GBE Family Controller' on local host
which is my LAN adapter. Make sure you also select the hardware adapter.
I am using DHCP, but ping also works with a static IP-address.
Ping also works like this:
ping RTOSDemo
because LLMNR is enabled.
And finally, FileZilla also works from the same laptop:
Host : 192.168.2.124 ( or “RTOSDemo” )
Port : 21
Encryption : Only Plain FTP (insecure)
Login type: Normal
User/Password: don’t care
At the bottom of this post you will find an attachment FreeRTOS-Plus-FAT_2019_nov_13.7z which contains the latest (non-official) release of FreeRTOS+FAT.
I recommend using the AWS/FreeRTOS release for all other libraries.
I pressed on “Post” in stead of “Attach”.
This post will contain the most recent release of FreeRTOS+FAT. You will find some small differences with the 2016-release.
Hein
Hein,
Thank you for the quick response, and for the link to the latest sources. I did have the correct hardware adapter selected, and, to be clear, if I was not, I was ultimately able to ping/run ftp from another machine to the Win 10 machine. My last action yesterday was to download the 10.2.1 installer for sources to start fresh today; I will instead start with the source you linked to. While I’ve been away from the nitty-gritty of embedded work since the 1990s (the world was very different then,…) my first impressions of FreeRTOS are positive (early glitches notwithstanding).
Jack
The latest version should be that found in the FreeRTOS-Labs directory of the main FreeRTOS repo in SourceForce SVN (which is also currently mirrored into https://github.com/freertos). If that is not the case then please work with me to update the code there then we can ensure that is always the single source of truth for that library.
