cmauler wrote on Monday, May 30, 2011:
My test collects adc data under 100Hz interrupt (using xQueueSendFromISR ) and the highest priority task unloads the data but the queue only works for a few minutes. I see the interrupt routine still gets executed and another lower priority delay based task is unaffected.
I have changed queue length, task priority, stack size etc read numerous examples and I have stack check enabled, but I’m at a loss when the queue ceases to indicate received after a few thousand correct operations!
Also
Latest FreeRTOS V7.0.1
Copied ISR from PIC24 port demo serial handler
Vindicated hardware, as I substituted the queue with a C based creation based on shared variable with flags, and it ran overnight without issue.
Suggestions for possible/typical reasons or line of experimentation to determine cause?
Thank you for your time and consideration
