Which MCU are you using? That makes a big difference to the what might
be suggested.
Which version of FreeRTOS are you using? That makes a difference to the
diagnostic information the RTOS can provide through assert points.
How do you know the interrupt is still firing, and Q->uxMessagesWaiting
is not zero? Is that an assumption, or have counted the interrupts that
are occurring and viewing Q->uxMessageWaiting using the debugger?
In the actual code, are you making use of the last parameter in the call
to xQueueSendFromISR() to request a context switch from the ISR? See
the example code on the following page: http://www.freertos.org/a00119.html
I’m using CM4. Version 7.x (I’ll check exactly tomorrow). For checking the uxMessagesWaiting I use a debugger. I use configASSERT() and stack overflow (2) is used. Last parameter to the xQueueSendFromISR() is set to NULL (I remember the version we use allows to use NULL).
Most likely problem is an interrupt priority misconfiguration. This is
a very common (the most common) cause of support requests, so while its
not certain, it is a good bet. Later versions of FreeRTOS (the current
is V9.0.0) have much more configASSERT() statements to try and trap just
that error. I would recommend updating your FreeRTOS version to a newer
version as a first step to see if any asserts get hit.
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
The system is actually alive, meaning other tasks are running (few of them). And when I investigated the ‘suspended list’ I could find my TaskA on that list.
Upgrading the FreeRTOS to latest version is out of question, since we are in final stage of the development. We rather want to get to the bottom of this issue.
That would seem to be right. Check the value of configPRIO_BITS. Is it
hard coded or is it set to a value read from a header file? As we have
known the header files provided by vendors to be wrong before.
I’m afraid I can’t do anything with that information - first because you
didn’t say which MCU you were using when asked, and second it will be up
to you to determine if this is correct. We have seen the value being
wrong in both the header file and user manuals provided by MCU vendors,
so some times you need to figure it out yourself (which can be done by
writing 255 into a priority register, then reading the value back, to
see how many bits ‘stick’ at 1 and how many are read back as 0 - I think
the very latest versions of FreeRTOS will validate this automatically if
configASSERT() is defined, but it might be that only the head revision
in SVN does it).
IRQ bellow:
There is nothing obviously wrong in your code, provided uart_read() is
doing nothing more than reading a character you know is already
available from a register.
It might be an idea to create a very simple test that does not touch the
UART peripheral, but instead sends dummy characters to the queues from a
timer interrupt, or something similar, so you can see if you can
replicate the issue using basic dummy data from a simple ISR that just
has a few lines of code in it.
