nobody wrote on Friday, April 20, 2007:
When I build a PIC Demo3 on a 18F452 on a Microchip PicDem 2 Plus it work fine (all I did was add 4 LED to port D), the serial out send char "A to X" with out any problems… but when I re compile for an 18F4620 (a larger code and ram base) the serial port sends "A to O", short a few charterers?? I do not understand what can cause this???
Anyone have any ideas?? both are running with a 10mhz xtal and 4xPLL… baudrate is 57.6kb
Demo 1 and 2 work just fine…
thanks…
tom lafleur
xxxx@xxxx
also looking for a HD44780 LCD driver and PWM drivers that work under FreeRTOS
