Creating PIC18F25K20 Port to FreeRTOS
wykamakura wrote on Friday, January 17, 2014:
I’m trying to create a PIC18F25K20 Port do FreeRTOS and although rtosdemo1, rtosdemo2 and rtosdemo3 compiled OK I got many warning messages.
I’m using: MPLAB C18 V3.46
FreeRTOSV7.6.0
Linker from Voloviq (FreeRTOSV7.1.0 on PIC18F25k80 Queue - Uart) listed below:
// File: 18f25k80_g.lkr
// Generic linker script for the PIC18F25K80 processor
#DEFINE _CODEEND _DEBUGCODESTART - 1
#DEFINE _CEND _CODEEND + _DEBUGCODELEN
#DEFINE _DATAEND _DEBUGDATASTART - 1
#DEFINE _DEND _DATAEND + _DEBUGDATALEN
LIBPATH .
#IFDEF _CRUNTIME
#IFDEF _EXTENDEDMODE
FILES c018i_e.o
FILES clib_e.lib
FILES p18F25K80_e.lib
#ELSE
FILES c018i.o
FILES clib.lib
FILES p18F25K80.lib
#FI
#FI
#IFDEF _DEBUGCODESTART
CODEPAGE NAME=page START=0x0 END=_CODEEND
CODEPAGE NAME=debug START=_DEBUGCODESTART END=_CEND PROTECTED
#ELSE
CODEPAGE NAME=page START=0x0 END=0x7FFF
#FI
CODEPAGE NAME=userid START=0x200000 END=0x200007 PROTECTED
CODEPAGE NAME=cfgmem START=0x300000 END=0x30000D PROTECTED
CODEPAGE NAME=devid START=0x3FFFFE END=0x3FFFFF PROTECTED
CODEPAGE NAME=eedata START=0xF00000 END=0xF003FF PROTECTED
DATABANK NAME=gpre START=0x0 END=0x5F
#ELSE
ACCESSBANK NAME=accessram START=0x0 END=0x5F
#FI
//DATABANK NAME=gpr0 START=0x60 END=0xFF
//DATABANK NAME=gpr1 START=0x100 END=0x1FF
//DATABANK NAME=gpr2 START=0x200 END=0x2FF
//DATABANK NAME=gpr3 START=0x300 END=0x3FF
//DATABANK NAME=gpr4 START=0x400 END=0x4FF
//DATABANK NAME=gpr5 START=0x500 END=0x5FF
//DATABANK NAME=gpr6 START=0x600 END=0x6FF
//DATABANK NAME=gpr7 START=0x700 END=0x7FF
//DATABANK NAME=gpr8 START=0x800 END=0x8FF
//DATABANK NAME=gpr9 START=0x900 END=0x9FF
//DATABANK NAME=gpr10 START=0xA00 END=0xAFF
//DATABANK NAME=gpr11 START=0xB00 END=0xBFF
//DATABANK NAME=gpr12 START=0xC00 END=0xCFF
DATABANK NAME=BIG_BLOCK START=0x60 END=0xAFF
DATABANK NAME=gpr12 START=0xB00 END=0xCFF PROTECTED
#IFDEF _DEBUGDATASTART
DATABANK NAME=gpr13 START=0xD00 END=_DATAEND
DATABANK NAME=dbgspr START=_DEBUGDATASTART END=_DEND PROTECTED
#ELSE //no debug
DATABANK NAME=gpr13 START=0xD00 END=0xDFF
#FI
DATABANK NAME=gpr14 START=0xE00 END=0xE40
DATABANK NAME=sfr14 START=0xE41 END=0xEFF PROTECTED
DATABANK NAME=sfr15 START=0xF00 END=0xF5F PROTECTED
ACCESSBANK NAME=accesssfr START=0xF60 END=0xFFF PROTECTED
#IFDEF _CRUNTIME
SECTION NAME=CONFIG ROM=cfgmem
STACK SIZE=0x1FF RAM=gpr12
#ELSE
#FI
#FI
In port.c ,
I needed to make the following changes:
Include defines to config:
#pragma config WDTEN = OFF
#pragma config FOSC = INTIO2
#pragma config XINST = OFF
Because there are slight difference in register:
Line 561 if( PIR1bits.CCP1IF ) to if( PIR3bits.CCP1IF )
Line 602 PIR1bits.CCP1IF = 0; to PIR3bits.CCP1IF = 0;
Line 643 PIE1bits.CCP1IE = portBIT_SET; to PIE3bits.CCP1IE = portBIT_SET;
Line 651 OpenTimer1( T1_16BIT_RW & T1_SOURCE_INT & T1_PS_1_1 & T1_CCP1_T3_CCP2 ); to
            OpenTimer1(T1_SOURCE_FOSC_4 & T1_PS_1_1 & T1_OSC1EN_ON & T1_SYNC_EXT_OFF & T1_16BIT_RW , TIMER_GATE_OFF & TIMER_GATE_POL_HI & 	 TIMER_GATE_TOGGLE_OFF & TIMER_GATE_1SHOT_OFF & TIMER_GATE_INT_OFF);
In ParTest.c:
Modified PortD to PortB
PortE to PortC
Renamed : timers.h in C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Source\include to timers_.h because
there are a conflict with timers.h in C:\Program Files\Microchip\MPLABC18\v3.46\h
during compilation.
Before compilation it is necessary to set the “Build Options” of MPLAB:
        Hex format : INHX32
        Memory Model:
                      Code Model -> Small Code Model
                      Data Model -> Large Data Model
                      Stack Model-> Multi Bank Model
        Generate Command Line -> uncheck -> Extended Mode
Messages I got:
rtosdemo1
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “tasks.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\tasks.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Source\tasks.c:556:Warning [2066] type qualifier mismatch in assignment
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “queue.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\queue.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “list.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\list.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “port.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\port.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “PollQ.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\PollQ.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “main1.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\main1.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “ParTest.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\ParTest.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “serial.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\serial.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:219:Warning [2074] location PRODH specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:219:Warning [2074] location PRODL specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:219:Warning [2074] location TABLAT specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:219:Warning [2074] location .tmpdata specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:246:Warning [2074] location PRODH specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:246:Warning [2074] location PRODL specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:246:Warning [2074] location TABLAT specified in the interrupt save list is redundant
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\serial\serial.c:246:Warning [2074] location .tmpdata specified in the interrupt save list is redundant
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “integer.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\integer.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “heap_1.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\heap_1.o” -w3 -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mplink.exe” /p18F25K80 /l"C:\Arquivos de programas\Microchip\MPLABC18\v3.46.lib" /k"C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB" “…\18f25k80.lkr” “…\OBJ\tasks.o” “…\OBJ\queue.o” “…\OBJ\list.o” “…\OBJ\port.o” “…\OBJ\PollQ.o” “…\OBJ\main1.o” “…\OBJ\ParTest.o” “…\OBJ\serial.o” “…\OBJ\integer.o” “…\OBJ\heap_1.o” /u_CRUNTIME /z__MPLAB_BUILD=1 /m"rtosdemo1.map" /w /o"rtosdemo1.cof"
MPLINK 4.48, Linker
Device Database Version 1.13
Copyright © 1998-2011 Microchip Technology Inc.
Errors : 0
MP2HEX 4.48, COFF to HEX File Converter
Errors : 0
rtosdemo2
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “main2.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\main2.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\main2.c:144:Warning [2058] call of function without prototype
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “serial.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\serial.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “ParTest.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\ParTest.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “tasks.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\tasks.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “queue.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\queue.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “list.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\list.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “heap_1.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\heap_1.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “flash.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\flash.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mcc18.exe” -p=18F25K80 /i"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\h" -I"." -I".\include" -I"…\include" -I"…\include" -I"…\include" -I"…\Source\include" -I"…\Source\include" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Demo\PIC18_MPLAB" -I"…\Common\include" -I"…\Common\include" “port.c” -fo=“C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB\OBJ\port.o” -DMPLAB_PIC18F_PORT -Ls -Opa-
Executing: “C:\Arquivos de programas\Microchip\MPLABC18\v3.46\bin\mplink.exe” /p18F25K80 /l"C:\Arquivos de programas\Microchip\MPLABC18\v3.46\lib" /k"C:\FreeRTOSV7.6.0_PIC18F25K80\FreeRTOS\Demo\PIC18_MPLAB" “…\18f25k80.lkr” “…\OBJ\main2.o” “…\OBJ\serial.o” “…\OBJ\ParTest.o” “…\OBJ\tasks.o” “…\OBJ\queue.o” “…\OBJ\list.o” “…\OBJ\heap_1.o” “…\OBJ\flash.o” “…\OBJ\port.o” /u_CRUNTIME /z__MPLAB_BUILD=1 /m"rtosdemo2.map" /o"rtosdemo2.cof"
MPLINK 4.48, Linker
Errors : 0
Errors : 0
rtosdemo3
        Compiled OK without messages.
Finally I ask anyone: How to correct port.c to avoid the “Warning Messages”?
Regards
rtel wrote on Saturday, January 18, 2014:
I’m afraid we don’t encourage the use of FreeRTOS on PIC18 devices, the architecture and non re-entrant compiler do not make it a suitable target. I’m also not sure what Voloviq is, but if you got the code from Voloviq I suggest you ask whoever created or maintained Voloviq for support.
