Firstly, thanks for an excellant job with FreeRTOS, i have been using the demo apps and its very impressive.
My problem:
using C18+MPLAB
I can compile the demo’s fine, using a 18f452 as the device, i want to get it working on a 18f458 - and eventually a 18f4550, but i am having trouble with this task.
if i select the device as an 18f458, open up the linker script and change the FILES p18f452.lib line to FILES p18f458.lib, and recompile i get a
section ‘SFR_BANKED0’ can not fit the absolut section. Section ‘SFR_BANKED0’ start=0x00000f00 length=0x0000002f
error, i am thinking this is due to the extra features built into this chip affecting the sfr size
can you help me out with this? i have tried many changes in the .lkr file but no success
I have not used a 456 device, but the RAM layout for program usage I think is the same, so this is odd.
Try taking the 456 linker file and converting it for use with FreeRTOS. Basically you have to create one large block. You can use the existing file as a template, and see if you notice anything very different between the two.
Thanks for your response, i have tried many different variations to this for the 458, the latest one is below, which is practically identical to the microchip one apart from the bigblock part
MPLINK 4.00, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - section ‘.udata_c018i.o’ can not fit the section. Section ‘.udata_c018i.o’ length=0x0000000a
Errors : 1
