In PC folder i have not use existing main.c, I have make my own make new main.c using existing main.c
Very simple appl.
Create queue
create task
task function entry : sending mes and receiving mes
Run successfully but after 1 sec gives this message
16 bit MS-DOS Subsystem
C:\FreeRTOS\Demo\PC\rtosdemo.exe
The NTVDM CPU has encountered an illegal instruction.
CS:1044 IP:a72c OP:ff ff 00 00 4d Choose ‘close’ to terminate the application
close Ignore
What could be the problem?
Can anyone support me?
Thanks
If anyone done application on PC like me, anyone got same error? what could be the reason?
it is very important for me to remove error, b’coz i don’t have any other hardware to test functionality of RTOS.
