Outdated corePKCS11 Integration Test code?
Greetings,
After updating from FreeRTOS 202210.00 LTS to 202406.01 LTS, corePKCS11 library is updated to v3.6.3.
After applying corePKCS11 v3.6.3, I tried to run FreeRTOS-Libraries-Integration-Testsas verification.
I encountered 2 failed test cases:
  • PKCS11_RSA_GetAttributeValue
  • PKCS11_RSA_GetAttributeValueMultiThread
I believe these test cases failed due to outdated core_pkcs11_test.c.
I managed to PASS these test cases by replacing CKA_PRIVATE_EXPONENT with CKA_VALUE in core_pkcs11_test.c#L1681 and core_pkcs11_test.c#L1835.
This solution is based on corePKCS11 changes in mbedtls_integration_test.c from merge request#202 @ commit#470ccc3.
Request: Please advise whether this approach is acceptable?
Thank you.
Yes, that looks correct. Would you please raise a PR?
Thanks for the confirmation, @aggarg.
I’ve raised a PR to fix this issue: Pull Request #74
Thank you for your contribution!
