Running on ESP32S3. Observe this after OTA has completed:
I (9349) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (9356) AWS_OTA: Current State=[CreatingFile], Event=[ReceivedJobDocument], New state=[CreatingFile]
I (9372) AWS_OTA: Beginning self-test.
I (9376) AWS_OTA: otaPal_GetPlatformImageState
I (9381) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (9387) esp_ota_ops: [1] aflags/seq:0x2/0x4, pflags/seq:0x2/0x3
W (9394) AWS_OTA: Rejecting new image and rebooting:The job is in the self-test state while the platform is not.
I (9405) AWS_OTA: otaPal_SetPlatformImageState, 3
W (9410) AWS_OTA: Set image as invalid!
More details…
Start
I (6872) AWS_OTA: otaPal_GetPlatformImageState
I (6877) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (6883) esp_ota_ops: [0] aflags/seq:0x2/0x3, pflags/seq:0x3/0x0
I (6890) AWS_OTA: Current State=[RequestingJob], Event=[Start], New state=[RequestingJob]
I (7874) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (7880) coreMQTT: SUBSCRIBE topic $aws/things/x062200004/jobs/notify-next to broker.
I (7882) AWS_OTA: Subscribed to MQTT topic: $aws/things/x062200004/jobs/notify-next
I (7992) coreMQTT: Received SUBACK.
I (7993) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (8210) coreMQTT: Ack packet deserialized with result: MQTTSuccess.
I (8211) coreMQTT: State record updated. New state=MQTTPublishDone.
PUBACK received for packet id 2.
I (8217) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/$next/get to broker.
I (8221) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
W (8228) AWS_OTA: OTA Timer handle NULL for Timerid=0, can't stop.
I (8237) coreMQTT: State record updated. New state=MQTTPublishDone.
I (8244) AWS_OTA: Current State=[WaitingForJob], Event=[RequestJobDocument], New state=[WaitingForJob]
I (8251) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/$next/get/accepted
I (8276) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (8279) AWS_OTA: No active job available in received job document: OtaJobParseErr_t=OtaJobParseErrNoActiveJobs
I (8293) AWS_OTA: otaPal_GetPlatformImageState
I (8298) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (8304) esp_ota_ops: [0] aflags/seq:0x2/0x3, pflags/seq:0x3/0x0
I (8311) AWS_OTA: Current State=[WaitingForJob], Event=[ReceivedJobDocument], New state=[CreatingFile]
I (9289) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (10295) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (11301) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (11761) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (11762) coreMQTT: State record updated. New state=MQTTPublishDone.
I (11767) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/notify-next
I (11783) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (11786) AWS_OTA: Extracted parameter: [key: value]=[execution.jobId: AFR_OTA-OtaSensorTest6]
I (11804) AWS_OTA: Extracted parameter: [key: value]=[execution.jobDocument.afr_ota.streamname: AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a]
I (11813) AWS_OTA: Extracted parameter: [key: value]=[execution.jobDocument.afr_ota.protocols: ["MQTT"]]
I (11824) AWS_OTA: Extracted parameter: [key: value]=[filepath: /]
I (11829) AWS_OTA: Extracted parameter: [key: value]=[filesize: 1569280]
I (11837) AWS_OTA: Extracted parameter: [key: value]=[fileid: 0]
I (11843) AWS_OTA: Extracted parameter: [key: value]=[certfile: Code Verify Key]
I (11853) AWS_OTA: Extracted parameter [ sig-sha256-ecdsa: MEQCIGDnxeN5XkZPhf+lgf/OGFrJ/8hZ... ]
I (11862) AWS_OTA: Job document was accepted. Attempting to begin the update.
I (11868) AWS_OTA: Job parsing success: OtaJobParseErr_t=OtaJobParseErrNone, Job name=AFR_OTA-OtaSensorTest6
I (11879) AWS_OTA: otaPal_GetPlatformImageState
I (11884) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (11890) esp_ota_ops: [0] aflags/seq:0x2/0x3, pflags/seq:0x3/0x0
I (11896) AWS_OTA: Writing to partition subtype 17 at offset 0x320000
I (12795) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (12965) AWS_OTA: esp_ota_begin succeeded
I (12966) AWS_OTA: otaPal_GetPlatformImageState
I (12966) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (12971) esp_ota_ops: [0] aflags/seq:0x2/0x3, pflags/seq:0x3/0x0
I (12977) AWS_OTA: Setting OTA data interface.
I (12984) AWS_OTA: Current State=[CreatingFile], Event=[ReceivedJobDocument], New state=[CreatingFile]
I (13837) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (13844) coreMQTT: SUBSCRIBE topic $aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/data/cbor to broker.
I (13846) AWS_OTA: Current State=[RequestingFileBlock], Event=[CreateFile], New state=[RequestingFileBlock]
I (14111) coreMQTT: Received SUBACK.
I (14113) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (14118) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/get/cbor to broker.
I (14126) AWS_OTA: Published to MQTT topic to request the next block: topic=$aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/get/cbor
I (14142) AWS_OTA: Current State=[WaitingForFileBlock], Event=[RequestFileBlock], New state=[WaitingForFileBlock]
I (14503) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (14504) coreMQTT: State record updated. New state=MQTTPublishDone.
I (14509) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/streams/#, TopicName=$aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/data/cbor
I (14528) coreMQTT: Received data message callback, size 4120.
I (14563) AWS_OTA: Received valid file block: Block index=1, Size=4096
I (14564) coreMQTT: Received: 1 Queued: 1 Processed: 0 Dropped: 0
I (14582) coreMQTT: Received: 1 Queued: 1 Processed: 0 Dropped: 0
I (14593) AWS_OTA: Number of blocks remaining: 383
I (14673) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (14674) coreMQTT: State record updated. New state=MQTTPublishDone.
I (14679) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/streams/#, TopicName=$aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/data/cbor
I (14698) coreMQTT: Received data message callback, size 4120.
I (14706) coreMQTT: Received: 2 Queued: 2 Processed: 1 Dropped: 0
I (14714) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update to broker.
I (14717) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (14725) AWS_OTA: Current State=[WaitingForFileBlock], Event=[ReceivedFileBlock], New state=[WaitingForFileBlock]
I (14734) coreMQTT: State record updated. New state=MQTTPublishDone.
I (14745) AWS_OTA: Received valid file block: Block index=0, Size=4096
I (14752) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/streams/#, TopicName=$aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/data/cbor
I (14778) coreMQTT: Received data message callback, size 4120.
then lots of log output that looks the same, finishing with
(96224) AWS_OTA: Received valid file block: Block index=382, Size=4096
I (96225) coreMQTT: Received: 383 Queued: 383 Processed: 382 Dropped: 0
I (96245) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (96249) coreMQTT: State record updated. New state=MQTTPublishDone.
I (96255) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/streams/#, TopicName=$aws/things/x062200004/streams/AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a/data/cbor
I (96256) AWS_OTA: Number of blocks remaining: 1
I (96275) coreMQTT: Received data message callback, size 538.
I (96281) AWS_OTA: Current State=[WaitingForFileBlock], Event=[ReceivedFileBlock], New state=[WaitingForFileBlock]
I (96287) coreMQTT: Received: 384 Queued: 384 Processed: 383 Dropped: 0
I (96299) AWS_OTA: Received valid file block: Block index=383, Size=512
I (96315) AWS_OTA: Received final block of the update.
I (97249) AWS_OTA: Signature verification succeeded.
I (97251) AWS_OTA: Received entire update and validated the signature.
I (97314) coreMQTT: Received: 384 Queued: 384 Processed: 383 Dropped: 0
I (97351) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update to broker.
OTA_MQTT: Received OtaJobEventActivate (new image) callback from OTA Agent.
I (97360) esp_image: segment 0: paddr=00320020 vaddr=3c120020 size=49fa4h (303012) map
I (97434) esp_image: segment 1: paddr=00369fcc vaddr=3fc99820 size=05e2ch ( 24108)
I (97440) esp_image: segment 2: paddr=0036fe00 vaddr=40374000 size=00218h ( 536)
I (97442) esp_image: segment 3: paddr=00370020 vaddr=42000020 size=119b40h (1153856) map
I (97467) coreMQTT: Ack packet deserialized with result: MQTTSuccess.
I (97469) coreMQTT: State record updated. New state=MQTTPublishDone.
PUBACK received for packet id 68.
I (97475) coreMQTT: Received: 384 Queued: 384 Processed: 384 Dropped: 0
I (97492) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (97494) coreMQTT: State record updated. New state=MQTTPublishDone.
I (97500) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted
I (97517) coreMQTT: Received job message $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted{"timestamp":1674245000}rdyaf size 24.
I (97532) coreMQTT: Received: 384 Queued: 384 Processed: 384 Dropped: 0
I (97736) esp_image: segment 4: paddr=00489b68 vaddr=40374218 size=155fch ( 87548)
I (97756) esp_image: segment 5: paddr=0049f16c vaddr=50000200 size=00034h ( 52)
I (97757) esp_image: segment 6: paddr=0049f1a8 vaddr=600fe000 size=00028h ( 40)
I (97763) esp_image: segment 0: paddr=00320020 vaddr=3c120020 size=49fa4h (303012) map
I (97835) esp_image: segment 1: paddr=00369fcc vaddr=3fc99820 size=05e2ch ( 24108)
I (97841) esp_image: segment 2: paddr=0036fe00 vaddr=40374000 size=00218h ( 536)
I (97843) esp_image: segment 3: paddr=00370020 vaddr=42000020 size=119b40h (1153856) map
I (98101) esp_image: segment 4: paddr=00489b68 vaddr=40374218 size=155fch ( 87548)
I (98121) esp_image: segment 5: paddr=0049f16c vaddr=50000200 size=00034h ( 52)
I (98122) esp_image: segment 6: paddr=0049f1a8 vaddr=600fe000 size=00028h ( 40)
I (98545) coreMQTT: Received: 384 Queued: 384 Processed: 384 Dropped: 0
I (98665) wifi:state: run -> init (0)
I (98666) wifi:pm stop, total sleep time: 52659418 us / 95126318 us
W (98667) wifi:<ba-del>idx
W (98668) wifi:<ba-del>idx
I (98669) wifi:new:<2,0>, old:<2,0>, ap:<255,255>, sta:<2,0>, prof:1
WiFi disconnected, reason 8, WIFI_REASON_ASSOC_LEAVE
E (98682) esp-tls-mbedtls: read error :-0x004C:
E (98685) coreMQTT: Call to receiveSingleIteration failed. Status=MQTTRecvFailed
E (98693) coreMQTT: MQTT_ProcessLoop returned with status = MQTTRecvFailed.
I (98701) coreMQTT: Disconnecting the MQTT connection with aojzzp6jejodz-ats.iot.us-east-1.amazonaws.com.
E (98713) esp-tls-mbedtls: write error :-0x004E:
E (98716) coreMQTT: sendBuffer: Unable to send packet: Network Error.
E (98724) coreMQTT: Transport send failed for DISCONNECT packet.
W (98732) AWS_OTA: OTA Timer handle NULL for Timerid=1, can't stop.
I (98746) wifi:flush txq
I (98746) wifi:stop sw txq
I (98747) wifi:lmac stop hw txq
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
finally
I (6674) coreMQTT: MQTT connection established with the broker.
I (6674) coreMQTT: MQTT connection successfully established with broker.
I (6705) AWS_OTA: otaPal_GetPlatformImageState
I (6710) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (6716) esp_ota_ops: [1] aflags/seq:0x2/0x4, pflags/seq:0x2/0x3
I (6723) AWS_OTA: Current State=[RequestingJob], Event=[Start], New state=[RequestingJob]
I (7707) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (7713) coreMQTT: SUBSCRIBE topic $aws/things/x062200004/jobs/notify-next to broker.
I (7714) AWS_OTA: Subscribed to MQTT topic: $aws/things/x062200004/jobs/notify-next
I (7818) coreMQTT: Received SUBACK.
I (7819) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (7978) coreMQTT: Ack packet deserialized with result: MQTTSuccess.
I (7981) coreMQTT: State record updated. New state=MQTTPublishDone.
I (7987) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/$next/get to broker.
I (7997) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
W (7998) AWS_OTA: OTA Timer handle NULL for Timerid=0, can't stop.
I (8007) coreMQTT: State record updated. New state=MQTTPublishDone.
I (8013) AWS_OTA: Current State=[WaitingForJob], Event=[RequestJobDocument], New state=[WaitingForJob]
I (8020) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/$next/get/accepted
I (8046) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (8049) AWS_OTA: Extracted parameter: [key: value]=[execution.jobId: AFR_OTA-OtaSensorTest6]
I (8063) AWS_OTA: Extracted parameter: [key: value]=[execution.statusDetails.updatedBy: 16908293]
I (8075) AWS_OTA: Extracted parameter: [key: value]=[execution.jobDocument.afr_ota.streamname: AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a]
I (8085) AWS_OTA: Extracted parameter: [key: value]=[execution.jobDocument.afr_ota.protocols: ["MQTT"]]
I (8096) AWS_OTA: Extracted parameter: [key: value]=[filepath: /]
I (8102) AWS_OTA: Extracted parameter: [key: value]=[filesize: 1569280]
I (8109) AWS_OTA: Extracted parameter: [key: value]=[fileid: 0]
I (8115) AWS_OTA: Extracted parameter: [key: value]=[certfile: Code Verify Key]
I (8126) AWS_OTA: Extracted parameter [ sig-sha256-ecdsa: MEQCIGDnxeN5XkZPhf+lgf/OGFrJ/8hZ... ]
I (8134) AWS_OTA: In self test mode.
I (8136) AWS_OTA: New image has a higher version number than the current image: New image version=1.2.6, Previous image version=1.2.5
I (8149) AWS_OTA: Image version is valid: Begin testing file: File ID=0
I (8156) AWS_OTA: otaPal_SetPlatformImageState, 1
W (8162) AWS_OTA: Set image as testing!
I (9059) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (9213) coreMQTT: Ack packet deserialized with result: MQTTSuccess.
I (9214) coreMQTT: State record updated. New state=MQTTPublishDone.
PUBACK received for packet id 3.
I (9220) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update to broker.
I (9225) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (9232) AWS_OTA: Job parsing success: OtaJobParseErr_t=OtaJobParseErrNone, Job name=AFR_OTA-OtaSensorTest6
I (9241) coreMQTT: State record updated. New state=MQTTPublishDone.
I (9251) AWS_OTA: otaPal_GetPlatformImageState
I (9258) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted
I (9263) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (9281) coreMQTT: Received job message $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted{"timestamp":1674245011}74245009,"execution":{"jobId":"AFR_OTA-OtaSensorTest6","status":"IN_PROGRESS","statusDetails":{"self_test":"ready","updatedBy":"0x01020005"},"queuedAt":1674244914,"startedAt":1674244917,"lastUpdatedAt":1674245000,"versionNumber":18,"executionNumber":1,"jobDocument":{"afr_ota":{"protocols":["MQTT"],"streamname":"AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a","files":[{"filepath":"/","filesize":1569280,"fileid":0,"certfile":"Code Verify Key","sig-sha256-ecdsa":"MEQCIGDnxeN5XkZPhf+lgf/OGFrJ/8hZ4nShkqpG7bpGS7y/AiAVEp9+hR9RYJH3TWQfl9a/iwMa5engJ8alCpkJNkZaDg=="}]}}}} size 24.
I (9286) esp_ota_ops: [1] aflags/seq:0x2/0x4, pflags/seq:0x2/0x3
I (9414) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (9420) esp_ota_ops: [1] aflags/seq:0x2/0x4, pflags/seq:0x2/0x3
W (9427) AWS_OTA: Image not in self test mode 2
I (9432) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (9437) esp_ota_ops: [1] aflags/seq:0x2/0x4, pflags/seq:0x2/0x3
I (10369) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (10543) coreMQTT: Ack packet deserialized with result: MQTTSuccess.
I (10544) coreMQTT: State record updated. New state=MQTTPublishDone.
PUBACK received for packet id 4.
I (10550) coreMQTT: Sent PUBLISH packet to broker $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update to broker.
I (10554) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (10571) coreMQTT: State record updated. New state=MQTTPublishDone.
I (10578) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted
I (10595) coreMQTT: Received job message $aws/things/x062200004/jobs/AFR_OTA-OtaSensorTest6/update/accepted{"timestamp":1674245012}74245009,"execution":{"jobId":"AFR_OTA-OtaSensorTest6","status":"IN_PROGRESS","statusDetails":{"self_test":"ready","updatedBy":"0x01020005"},"queuedAt":1674244914,"startedAt":1674244917,"lastUpdatedAt":1674245000,"versionNumber":18,"executionNumber":1,"jobDocument":{"afr_ota":{"protocols":["MQTT"],"streamname":"AFR_OTA-9c109bdd-5a13-4e16-8526-739eb0bbe78a","files":[{"filepath":"/","filesize":1569280,"fileid":0,"certfile":"Code Verify Key","sig-sha256-ecdsa":"MEQCIGDnxeN5XkZPhf+lgf/OGFrJ/8hZ4nShkqpG7bpGS7y/AiAVEp9+hR9RYJH3TWQfl9a/iwMa5engJ8alCpkJNkZaDg=="}]}}}} size 24.
I (10658) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
I (11003) coreMQTT: De-serialized incoming PUBLISH packet: DeserializerResult=MQTTSuccess.
I (11003) coreMQTT: State record updated. New state=MQTTPublishDone.
I (11008) coreMQTT: Invoking subscription callback of matching topic filter: TopicFilter=$aws/things/+/jobs/#, TopicName=$aws/things/x062200004/jobs/notify-next
I (11023) coreMQTT: Received: 0 Queued: 0 Processed: 0 Dropped: 0
Any thoughts as to next debug steps?
