nickm2018 wrote on February 05, 2019:
Are there any timeouts once subscribed to a OTA job? As i deploy more and more units I am running into situations where the library is still associated to a job that has either been canceled, deleted, or dropped from some reason. This causes the device to remain in a queued state for the next job.
Amazon FreeRTOS OTA Agent V1.0.0
Amazon FreeRTOS release 1.4.6
Two types of errors that i have captured from multiple attempts to get a device to start the download.
First error says the library is busy with existing job but there are no active jobs in the IoT console.
179776 347670946 [OTA Task] [prvParseJobDoc] Busy with existing job. Ignoring.
179777 347670946 [OTA Task] [prvParseJobDoc] Error 1 parsing job document.
179778 347670946 [OTA Task] [prvParseJobDoc] Rejecting job due to OTA_JobParseErr_t 1
179796 347671098 [OTA Task] [prvOTA_Close] Context->0x005599a4
This is the next attempt to send an image. It is about to start and then the mqtt library indicates subscribe limit is reached. The library has a max of 8 subscriptions. 2 are used by my application so there should be 6 left to the OTA (seems to only use 3).
179951 347887000 [OTA Task] [prvParseJobDoc] Job was accepted. Attempting to start transfer.
179952 347887000 [OTA Task] [OTA] cnewImageStatus = 0
179953 347887092 [OTA Task] [prvPAL_GetPlatformImageState] currentImageStatus = 0
179954 347887092 [OTA Task] Sending command to MQTT task.
179955 347887092 [MQTT] Received message 16fa0000from queue.
179956 347887092 [MQTT] Initiating MQTT subscribe.
179957 347887093 [MQTT] WARN: Subscription Manager full! No space left to store new subscriptions.
179958 347887093 [MQTT] MQTT_Subscribe failed!
Edited by: nickm2018 on Feb 5, 2019 3:08 PM
