I am using the AWS OTA Demo , modified with a time out if no update is found at power up. This means it can exit and get on with other things such as shadow or MQTT , this is working as expected with no issues and updates OTA work just fine.
The problem occurs when I run AWS OTA Demo from within the main program loop , I end up with a memory leak every time the OTA demo is run and eventually it crashes (out of memory).
To get it to run the subscriptions again , I add the following
xOTA_Agent.eState = eOTA_AgentState_Stopped;
xOTA_Agent.eImageState = eOTA_ImageState_Unknown;
to make it do a restart, without this it does not subscribe to the OTA topic and the demo timeouts out without any memory leak.
I cannot see were the leak is occurring or how to resolve the problem
any ideas welcome
thanks
pvyawaha
(Pvyawaha)
October 15, 2020, 8:40pm
2
Can you please share information on how you are using timeouts to stop the OTA Agent ? Are you shutting down the Agent and then reinitializing ?
Hi
Thanks for the response
Within vRunOTAUpdateDemo( pNetworkInterface, pNetworkCredentialInfo );
This routine has a for( ; ; ) loop in it which in the standard AWS code does not exit if no update is available
I have added a timeout variable which when zero runs a break; command to exist the for loop
Also after
I added, although this appear to have little effect in reducing memory leak
if( xSubscriptionHandle != IOT_NETWORK_MANAGER_SUBSCRIPTION_INITIALIZER )
AwsIotNetworkManager_RemoveSubscription( xSubscriptionHandle );
if( xNetworkAvailableLock != NULL )
vSemaphoreDelete( xNetworkAvailableLock );
if( bMqttInitialized == true )
IotMqtt_Cleanup();
Regards
Simon
Hi Again
Not sure how to go about stopping OTA_agent please advise
Thanks
pvyawaha
(Pvyawaha)
October 21, 2020, 5:07pm
5
The OTA Agent can be shutdown using the API described here https://freertos.org/Documentation/api-ref/ota/ota_function_shutdown.html which will perform the cleanup. You can then re initialize it based on your application requirement.
