osDelay() when the Tickless Idle Mode of FreeRTOS
masahoshi wrote on Wednesday, December 09, 2015:
I am trying to use the tickless idle mode using FreeRTOS 8.2.1 on STM32L476G-Discovery.
I am using a task which is blinking the LED for eacxNextTaskUnblockTime of prvGetExpectedIdleTime() was portMAX_DELAY, when pass a value to portSUPPRESS_TICKS_AND_SLEEP( xExpectedIdleTime ).
h 50ms, and want to confirm that if the action could be maintained in 50ms interval even in the tickless idle mode or not.
The action is confirmed good when release LowPower by Systick interrupt.
But when release LowPower by external interrupt, sometimes the action was not expected (means the action could not be maintained in 50ms interval) .
※ External interrupt is assigned the EXIT Line1 Interrupt to Left Botton of Joystick, press many times at irregular intervals.
I checked the output log via UART.
How can I keep the action in a 50ms interval when release LowPower by external interrupt?
rtel wrote on Wednesday, December 09, 2015:
If I understand you correctly, then when you use the default Cortex-M tickless idle mode then it is working as expected, but when you use the STM32L specific one you are getting the problem. If my understanding is correct, are you using the STM32L specific implementation found in the FreeRTOS zip file download?
The portMAX_DELAY value should be capped to the maximum possible sleep time (basically the time it takes for the timer to overflow) inside the suppress ticks and sleep function itself. Is the problem that this should be less than or equal to 50ms, rather than portMAX_DELAY, before it is passed into the suppress ticks and sleep function? Could you try V8.2.3 version, as some work was done there recently, although as I recall it was only to allow tickless idle when configUSE_PREEMPTION was 0 (which could not be done before).
masahoshi wrote on Thursday, December 10, 2015:
I tried V8.2.3.
When configUSE_PREEMPTION is 0, the NG behavior occured.
When configUSE_PREEMPTION is 1, the NG behavior did not occur.
Let me explain something about my test environment.
(1)I generated the code in the following set for STM32L476G-DISCO in STM32CubeMX V4.10.1(Firmware Package Name and Version is STM32Cube FW_L4 V1.0.0).
・FREERTOS : Enable
・USART2 : Asynchronous
・Assign the EXIT Line1 Interrupt to GPIO PA1 (JoyStick Left Botton)
・FREERTOSのUSE_PREEMPTION : Disable or Enable
・FREERTOSのUSE_TICKLESS_IDLE : Enable
(2) Based on the generated code, I added some changes.
・FREERTOS V8.2.1→V8.2.3
・Add the following code to main.c.
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here /
e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */
HAL_UART_Transmit(&huart2, (uint8_t )&ch, 1, 0xFFFF);
return ch;
void StartDefaultTask(void const * argument)
USER CODE BEGIN 5 /
uint32_t startTime, endTime;
Infinite loop /
for(;:wink:
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_2);
startTime = osKernelSysTick();
osDelay(50);
endTime = osKernelSysTick();
printf(“intvl=%d\n\r”, endTime - startTime);
USER CODE END 5 */
・Add the following code to mxconstants.h.
*****#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
(3) I started this program on the target board, and press quickly many times on the Left Botton of Joystick.
When it continued for about 10 minutes and the phenomenon occured.
Below is the log of TeraTerm when the phenomenon occured.
[Wed Dec 09 19:30:23.604 2015] intvl=50
[Wed Dec 09 19:30:23.667 2015] intvl=50
[Wed Dec 09 19:30:23.714 2015] intvl=50
[Wed Dec 09 19:30:23.760 2015] intvl=50
[Wed Dec 09 19:30:23.807 2015] intvl=50
[Wed Dec 09 19:30:24.073 2015] intvl=259
[Wed Dec 09 19:30:24.120 2015] intvl=50
[Wed Dec 09 19:30:24.167 2015] intvl=50
[Wed Dec 09 19:30:24.214 2015] intvl=50
[Wed Dec 09 19:30:24.276 2015] intvl=50
[Wed Dec 09 19:30:24.323 2015] intvl=50
[Wed Dec 09 19:30:35.372 2015] intvl=50
[Wed Dec 09 19:30:35.435 2015] intvl=50
[Wed Dec 09 19:30:35.482 2015] intvl=50
[Wed Dec 09 19:30:35.700 2015] intvl=218
[Wed Dec 09 19:30:35.747 2015] intvl=50
[Wed Dec 09 19:30:35.794 2015] intvl=50
[Wed Dec 09 19:30:35.841 2015] intvl=50
[Wed Dec 09 19:30:35.888 2015] intvl=50
[Wed Dec 09 19:30:35.950 2015] intvl=50
rtel wrote on Thursday, December 10, 2015:
Looking at the change history I see I made a mistake in my last post.
The changes to support tickless idle when configUSE_PREEMPTION is 0 are
not in V8.2.3, but in the head revision (in the public SVN repository)
http://www.freertos.org/History.txt
Is the log you show taken with configUSE_PREEMPTION set to 0?
I changed to use the latest FREERTOS revision (freertos-code-2396-trunk).
And the abnormal behavior no longer occurred when configUSE_PREEMPTION is 0.
I really appreciate you very much.
For reference!
In the below line of port.c
604 Line: configPRE_SLEEP_PROCESSING (xModifiableIdleTime)
611 Line: configPOST_SLEEP_PROCESSING (xExpectedIdleTime)
There is a compile error because of no “&”.
