There are 2 tasks:
Task 1, priority = MIN+1
Task 2, priority = MIN+5
Task 1 signals Task 2 but the higher priority task does not run immediately. Several signals are sent before Task 2 starts. I verified that PREEMPTION is enabled.
We are using the STMCube utilities for STM32F7xx processor to generate the FreeRTOS code. It is FreeRTOS version 9.
Sorry to hear you are having an issue but I’m afraid your post does not
provide enough information to answer your question. Perhaps if you
could start by describing how you are signalling one task from another,
and ideally post some code that is cut down to the bare minimum that
demonstrates the issue - for example a basic function that shows how the
signal (whatever that is) is being sent, and a basic function that shows
how the signal is being received.
