rehnnmanc wrote on Friday, May 18, 2018:
I’ve got a problem with Free RTOS and the timer service queue gettign full.
I’m usign FreeRTOS on a Kinetis uC with Kinetis Design Studio (an ecllipse derivative). I have task aware debugging (see below for screenshots).
I’ve tried increasing the queue length but that doesn’t stop the problem.
As I undertsand it the Timer Service queue is for timers waiting to be set, i.e. once a timer has been set it’s removed from the queue (regardless of wether the timer has requried). So my thoughts are either:
a - The Timer Service Task is being blocked meanign it can’t service the queue
Or
b - We’re over-loading the timer task by sendign too many timers at once.
So I have two questions:
1 - Are either of the above theories plausible?
2 - How can I debug the timer task/queue and work out what’s causing my issue?
