The target for my project is a FRDM-KL25Z board connected to a Raspberry Pi running Domoticz home automation. The development environment is Kinetis Design Studio 3.2 with the task aware plug-in installed. This is probably the 20th project I have done with FreeRTOS and ARM (M0, M0+ & M4) processors.
I’m having an issue in a task (named Dispatch) with a Queue that is also using an associated timer. This is the first time I have used a Queue with a timer as well. What happens is my code runs fine for an hour or up to 48+ hours. But at some point the Dispatch task waiting on a Queue post or timer expiration stops running. Right now I have “fixed” the problem by having this task be the one to tickle the watchdog.
When the task does stop running I can pause the debugger and the task state is showing as READY, but it never restarts. The Queue window shows that the Queue is full (16/16). The tic timer is still firing fine. The Queue timer for this task is set to 50mS if a post is not received.
The Dispatch task is the highest priority task and there are 4 other tasks in the system. The other 4 tasks still run fine after the Dispatch task locks up. There is a Console task that uses a Queue for new activity. There are 2 other tasks that run at a periodic rate using vTaskDelay() and the Idle task is still running fine. I have hooks for the Idle and Tic timer so I can see them running OK too.
The RTOS MaxSysCallInterruptPriority is set to 1. The tic rate is 10mS. The RTOS Interrupt Priority is set to 3.
The FRDM board has an XBee radio on one UART that receives periodic status updates from 3 other remote XBee radios at 30-60 second intervals. This UART runs at IRQ level 2 and uses the xQueueSendToBackFromISR() function to post the Dispatch task queue when a full packet arrives. I was using portEND_SWITCHING_ISR() to switch tasks, but I have that code commented out for now and just allow the next tic to switch. This interrupt routine is still running fine, but of course it gets errors on Queue posts since the queue is full.
I’ve tried making different “fixes” to diagnose the issue. I’ve set the stack sizes to really large numbers.
Is there something I might be missing or do you have any other ideas for a fix to try?
So the task is using a queue and a timer?
How is the task using the queue? Is it reading from the queue with a timeout?
How is the task using the timer? You say it is waiting for the timer to expire, but how does it know when the timer has expired?
Please paste in the structure of the task.
That is a very high priority. What is configMAX_SYSCALL_INTERRUPT_PRIORITY set to?
Here is how the task waits for the Queue post:
// Assign time to a variable so that we we can stop task by setting it to -1
// or 0xffffffff while debugging.
semphTime = MYS_DISPATCH_TASK_RTOS_TICS ;
// Wait for Pi or XBee input.
// Otherwise timeout and do housekeeping.
queExit = xQueueReceive( xQuePiXbeeMsg, &rxAdd, semphTime );
sempTime is set for 5 tics or 50mS so if there is no Queue post the timeout will occur and the task will do periodic housekeeping.
configMAX_SYSCALL_INTERRUPT_PRIORITY is set to 1.
configASSERT() is defined. I’m using Kinetis Design Studio with Processor Expert. FreeRTOS is 9.0.0
The port.c file you referenced above is quite a bit different than the one Erich Styger supplies with Processor Expert?? Not sure why?
If configMAX_SYSCALL_INTERRUPT_PRIORITY is 1 it is almost certainly wrong as that value should be left shifted. It is complicated but an attempt to explain this can be found on the following link: http://www.freertos.org/RTOS-Cortex-M3-M4.html
You mention originally that your task is using a queue and a timer. So far we can only see how the queue is being used, and as there doesn’t seem to be an issue with that small portion of the code it would be helpful to see a greater portion of the code, including the bit that is using the timer. So far no informatio is given as to what the task is doing with the timer (starting, stopping, resetting, being notified by the timer’s callback function, etc.).
Is it possible you are confusing my issue with another person?
Here is the line of code that waits:
Note that the task waits for a queue post in: xQuePiXbeeMsg
Or it waits for the timer in: semphTime
semphTime is set to 5 or 50mS in my case.
Therefore the task should resume upon a queue post in xQuePiXbeeMsg or it should resume after the 50mS timer in semphTime expires.
As you requested, here is more code showing what the task does when it gets a Queue post vs a timeout in the queue wait:
// This is pdTRUE if we get a messages from Pi or XBee and a Queue insertion.
if( queExit == pdTRUE )
// process data from Pi or XBee
if( *rxAdd == MESSAGE_SOURCE_PI )
// See who Domoticz needs to talk with?
ParsePiResponse( rxAdd );
else if( *rxAdd == MESSAGE_SOURCE_XBEE )
// Figure our which XBee this is.
ParseXbeeResponse( rxAdd ) ;
// Otherwise we timed out so do periodic updates for Domoticz.
// Get the RTC time.
ReadRtcTime() ;
// Update for KL25 sensors.
NodesKl25SensorUpdates( timeChangeFlag ) ;
// Updates for the garage doors.
NodesGarageDoorHousekeeping( timeChangeFlag ) ;
// Doorbell
NodesDoorbellHousekeeping( timeChangeFlag ) ;
timeChangeFlag = 0 ;
As I stated before this task eventually fails with the queue full. When I pause the debugger its status is showing ready, its queue is full and the timer (50mS) should have expired. All other tasks in the system are still running fine.
There are 5 tasks in the system. The task in question is the highest priority so it should not get starved. The task aware debugger shows the task in question is in the Ready state with a full queue but it never runs again after the lockup.
The other 4 tasks (one of which is Idle task) all are running fine and they are lower priority. The tic timer and idle hooks are also running fine. The locked up task should be brought out of the Ready state either as a result of queue posts or a timeout. Neither is happening.
How do you know it is waiting in the xQueueReceive() function and not locked somewhere else?
Add a new variable, set the variable to 1 before calling xQueueReceive() and 0 after calling xQueueReceive. When the task stops what is the variable set to?
Test is complete. I set a status bit to 1 prior to calling: xQueueReceive
If it exits because of a queue post or timeout then I immediately clear the status bit. Task locked up again this morning and the status bit is set to 1.
I’m not looking at the entire thread so am going from memory - apologies
if I have asked this before:
Are you using an idle hook function? If so, is it possible the idle
hook function is in a loop that is either in a critical section or has
the scheduler suspended?
I think you previously said you had configASSERT() defined, but were
using the NXP provided RTOS port layer. Does that port layer have
asserts that check the interrupt priority is at or below
configMAX_SYSCALL_INTERRUPT_PRIORITY (remembering that low interrupt
priority numbers mean high logical priority).
I do have a hook on the idle loop. All my code does is update a min & a max counter and check stack depth (uxTaskGetStackHighWaterMark) and then it returns to kernel.
I turned off configASSERT() about a week ago and it made no difference, the task till locks up.
OK - I’ve stopped calling that function in the Idle Task Hook function.
All my other tasks call uxTaskGetStackHighWaterMark() as well each time they come out of suspension. Should I stop calling from those tasks too or are you just interested in the Idle Task?
