Newbie: which freertos comes with ST CubeMX?
scott90 wrote on Tuesday, September 24, 2019:
Hi
I am a newbie to FreeRTOS, and use ST’s cubeMX. I heard that the cubeMX uses FreeRTOS library, but looking at the attached ,you can see I can only select CMSIS. A few things I am not sure about and hope someone can help?
  1. Is CMSIS and FreeRTOS (at www.freertos.org) 2 different libraries?
  2. If I create a bare project for my STM32 using cubeMX, will the free informaton at www.freertos.org be valid for my project?
Many Thanks
Scott
aggarg-aws wrote on Tuesday, September 24, 2019:
When you generate a project using CubeMX it comes with a CMSIS RTOS wrapper which maps CMSIS RTOS APIs to FreeRTOS APIs. You can still use FreeRTOS APIs directly and all the information provided on the freertos.org will still be applicable.
