hytromo wrote on Thursday, June 30, 2016:
Our processor runs a server in the background which listens for commands. We can command it to send a low value to a pin, wait a bit, and then reset the pin to the default high value.
Because of the running server, It is important that the above process is executed as a separate task.
As stated here http://www.freertos.org/a00126.html, we create the task (via xTaskCreate(mixer, "Mixer", UINT32_C(2048), NULL, UINT32_C(2), &mixerTask)) which calls the following function:
void mixer(void * pvParameters) {
(void) pvParameters;
// set PIN LOW code here
vTaskDelay(1000);
// set PIN HIGH code here
vTaskDelete(mixerTask); // delete the task itself (memory is scheduled for being freed)
The task runs each time our server receives a specific command, which is ~10-20 seconds.
Apart from the server, we have a timer (created via vTimerCreate) running every 600ms performing a simple task.
The problem is that we run out of memory after 3 calls to the vTaskCreate function. Searching the web reveals that the IDLE task is responsible for freeing the memory after the call to vTimerDelete.
Should we create this IDLE task ourselves or how else can we solve this problem?
