I have a problem on simulating FreeRTOS V6.0.4 with msp430fg4618 on IAR . When I build the project , appears many warnings like : { Warning: Only 16bit will be pushed to the stack. Use size specifier to avoid warning. } in " portasm.h" in function "portSAVE_CONTEX .
Can anyone help me , because I think this warnings is causing me a bug when I’m debugging demo code from the FreeRTOS for msp430
I’ve made some studies on the architecture after reading a post from this forum and it seems that the problem is in registers (different architecture) msp430fg4618 has 20 bit register like PC , SP …. It is possible to configure FreeROTS to run on such mcu ?
Were you able to resolve your problems of using FreeRTOS with MSP430FG4618? If so, I’d like to find out what you did. I’m encountering a similar difficulty. (Please see the post under anne13.)
