We are in the process of updating MQTT library from AWS IoT version to CoreMQTT & MQTT Agent.
It appears to work for the most of the part. However, we are always seeing this error if I run it long enough(roughly after 4 hours while sending about 6 MQTT messages every second to the broker).
Some logs are specific to our application but much of it comes from FreeRTOS libraries.
MQTT Agent and IP-task logs are 100% generic from FreeRTOS libraries.
- Once this error occurs, TCP socket connection keeps going back and forth between ESTABLISHED and CLOSED; as if IP-task and MQTT Agent were out of sync somehow?
- The whole error condition appears to be caused initially by “no space” error while FreeRTOS_send() is being executed.
- Then there is a spewing of [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
It would great if I could get some help on this.
910 15571379 1000000 [MQTT Agent] FreeRTOS_send: 55983 -> 127.255.255.255:1883: no space
911 15571379 999911 [MQTT Agent] Unable to send packet: Timed out in transport send.
912 15571379 999826 [MQTT Agent] Transport send failed for PUBLISH header.
913 15571379 999751 [MQTT Agent] MQTT PUBLISH failed with status MQTTSendFailed.
914 15571380 999670 [MQTT Agent] MQTT operation failed with status MQTTSendFailed
915 15571380 999588 [MQTT Agent] MQTT agent command loop exited(status = 3)
916 15571380 999512 [MQTT Agent] Disconnect socket
917 15571380 999461 [MQTT Agent] Disconnecting TCP connection.
918 15573631 1000000 [IP-task] FreeRTOS_closesocket[55983 to 127.255.255.255:1883]: buffers 60 socks 0
919 15573632 999897 [MQTT Agent] MQTT connection disconnected due to an error
920 15573632 999819 [MQTT Agent] Wait for MQTT_CONNECTED event
921 15573889 1000000 [MQTT] Notify->DISCONNECTED_BAD_PACKET
922 15573892 1000000 [MQTT] Try MQTT socket connect
923 15573892 999948 [MQTT] FreeRTOS_connect: 18098 to 127.255.255.255:1883
924 15573893 999873 [MQTT] Socket 18098 -> 127.255.25928 15574721 1000000 [NETIF_TASK] NetworkInterface: frame error
929 15574721 999935 [NETIF_TASK] Error Stats:
930 15574721 999888 [NETIF_TASK] statsRxLenGreaterErr 0
931 15574722 999829 [NETIF_TASK] statsRxAlignErr 0
932 15574722 999770 [NETIF_TASK] statsRxFcsErr 1
933 15574722 999711 [NETIF_TASK] statsRxOverRunErr 1
934 15574722 999652 [NETIF_TASK] statsRxTruncateErr 0
935 15574723 999593 [NETIF_TASK] NetworkInterface: frame error
936 15574723 999529 [NETIF_TASK] Error Stats:
937 15574723 999482 [NETIF_TASK] statsRxLenGreaterErr 0
938 15574723 999423 [NETIF_TASK] statsRxAlignErr 0
939 15574723 999364 [NETIF_TASK] statsRxFcsErr 2
940 15574724 999305 [NETIF_TASK] statsRxOverRunErr 2
941 15574724 999246 [NETIF_TASK] statsRxTruncateErr 0
942 15574724 999187 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
943 15574725 999098 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
944 15574725 999009 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
945 15574725 998920 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
946 15574726 998831 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
947 15574726 998742 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
948 15574727 998653 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
949 15574727 998564 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
950 15574727 998475 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1066 15574900 989585 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1067 15574901 989495 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1068 15574901 989405 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1069 15574901 989315 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1070 15574902 989225 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1071 15574902 989135 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1072 15574903 989045 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1073 15574903 988955 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1074 15574903 988865 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1075 15574904 988775 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1076 15574904 988685 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1077 15574904 988595 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1078 15574905 988505 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1079 15574905 988415 [IP-task] MSS change 1160 -> 1460
1080 15574906 988360 [IP-task] TCP: active 18098 => 127.255.255.255:1883 set ESTAB (scaling 1)
1081 15574906 988265 [IP-task] Socket 18098 -> 127.255.255.255:1883 State eCONNECT_SYN->eESTABLISHED
1082 15574918 988264 [MQTT] Try MQTT broker connect
1083 15575435 993712 [IP-task] TCP: No active socket on port 55983 (127.255.255.255:1883)
1084 15575475 994122 [MQTT] Send MQTT_CONNECTED event
1085 15575475 994068 [MQTT Agent] Received MQTT_CONNECTED event
1086 15575475 994004 [MQTT Agent] Service command loop
1087 15575480 993949 [MQTT] Connected to broker
1088 15575483 994001 [MQTT] Subscribing to Cmd/+/CabController/SetTime
1089 15575946 998130 [IP-task] TCP: RST received from 127.255.255.255:1883 for 18098
1090 15575946 998045 [IP-task] Socket 18098 -> 127.255.255.255:1883 State eESTABLISHED->eCLOSED
1091 15575947 997949 [MQTT Agent] Transport send failed. Error code=-128.
1092 15575947 997875 [MQTT Agent] Transport send failed for PUBLISH header.
1093 15575948 997799 [MQTT Agent] MQTT PUBLISH failed with status MQTTSendFailed.
1094 15575948 997717 [MQTT Agent] MQTT operation failed with status MQTTSendFailed
1095 15575948 997634 [MQTT Agent] MQTT agent command loop exited(status = 3)
1096 15575948 997557 [MQTT Agent] Disconnect socket
1097 15575948 997505 [MQTT Agent] Disconnecting TCP connection.
1098 15575949 997441 [IP-task] FreeRTOS_closesocket[18098 to 127.255.255.255:1883]: buffers 60 socks 0
