system
(system)
July 8, 2015, 4:51am
1
docsis wrote on Wednesday, July 08, 2015 :
In file rtosdemo_rdb1768_Debug.ld, The privileged_data section simply set as bss:
privileged_data :
_bss = .;
*(privileged_data)
/* Non kernel data is kept out of the first 256 bytes of SRAM. */
} > SRAM
But in task.c, not all variable is zero initial value:
PRIVILEGED_DATA static volatile TickType_t xNextTaskUnblockTime = portMAX_DELAY;
Not sure if this is an issue.
rtel
(Richard Barry)
July 9, 2015, 10:32am
2
rtel wrote on Thursday, July 09, 2015 :
Thanks for pointing this out - it is an interesting one and I’m afraid I don’t have an answer for how it worked however the head revision code no longer initialises this variable where it is declared, and instead initialises it immediately before the scheduler is started. The change was made explicitly to ensure the kernel itself had nothing outside the bss section.
You can see the head revision version here:
https://sourceforge.net/p/freertos/code/HEAD/tree/trunk/FreeRTOS/Source/tasks.c#l250
system
(system)
July 10, 2015, 12:26am
3
docsis wrote on Friday, July 10, 2015 :
Thank you for your reply. Yes, this is the only privileged variable with no-zero initial value.
There are some other minor issues in link script, maybe also not issues:
If enable timer, _Privileged_Data_Region_Size exceed 256.
If change flash start address to other value than zero, link fail. Have to change:
.text :
/* Non privileged code kept out of the first 16K or flash. */
. = privileged_functions_start + _Privileged_Functions_Region_Size;
to
.text :
. = ORIGIN( FLASH ) + _Privileged_Functions_Region_Size;
In my environment, need change these to get right link result.
3. Also have to change this to put .bss after _Privileged_Data_Region_Size.
. = ORIGIN( SRAM ) + _Privileged_Data_Region_Size;
.bss :
*(.bss*)
*(COMMON)
_ebss = .;
} > SRAM
to
.bss :
*(.bss*)
*(COMMON)
_ebss = .;
} > SRAM
