Microcontroller: similar examples
So I see you have a bunch of source code examples. I currently have a NXP Kinetis® K64-120 MHz, 256 KB SRAM Microcontrollers (MCUs) Based on Arm® Cortex®-M4 Core board. I see you have the Freescale: Kinetis ARM Cortex-M4 board. Beyond that, what would be good source code compatible examples to build experience on ?
If you are trying to learn FreeRTOS, you can use the following tutorials: GitHub - FreeRTOS/Lab-Project-FreeRTOS-Tutorials: Tutorials to learn FreeRTOS Kernel. · GitHub.
