I am trying make the LPC2368 webserver projects using Eclipse and as well "make". I successfully get .hex file in both senerio but once I download it to my LPC2300 board through the serial port using "flashmagic", the LCD does not shown as "PASS" and all the LEDs remained lid.
I also try to disable MAM and it remain the same. I have the lastest GNU Make 3.81, and arm-elf-gcc (GCC) 4.2.2.
There are some warnings there but I dont think any errors. Looks like the interface is working but when it tried to stop the processor it was already stopped. It should get past that though.
I think possibly you meant mainCPU_CLK_DIV = 3. This should produce a clock of 48MHz.
The LPC2368 manual states:
"Only 0 and odd values (1, 3, 5, …, 255) are supported and can be
used when programming the CCLKSEL bits.
Warning: Using an even value (2, 4, 6, …, 254) when setting the
CCLKSEL bits may result in incorrect operation of the device."
