/* A 1ms tick does not require the use of the timer prescale. This is
defaulted to zero but can be used if necessary. */
T0_PR = portPRESCALE_VALUE;
/* Calculate the match value required for our wanted tick rate. */
ulCompareMatch = configCPU_CLOCK_HZ / configTICK_RATE_HZ;
/* Protect against divide by zero. Using an if() statement still results
in a warning - hence the #if. */ #if portPRESCALE_VALUE != 0
ulCompareMatch /= portPRESCALE_VALUE;
ERROR: -> xxxxxxxxxxxxxxxxxxxxxxx
} #endif
because in the manual is written:
The Prescale
Counter is incremented on every pclk. When it reaches the value stored in the Prescale Register, the Timer Counter is
incremented and the Prescale Counter is reset on the next pclk. This causes the TC to increment on every pclk when PR = 0,
every 2 pclks when PR = 1, etc.
I believe there is another error (off-by-one) in Timer0Setup, but it is very small for typical LPC peripheral clock rates.
Currently, the Timer0 match register (MR0) is set as follows:
ulCompareMatch = configPCLK_HZ / configTICK_RATE_HZ;
ulCompareMatch /= ( portPRESCALE_VALUE + 1 );
} #endif
T0_MR0 = ulCompareMatch;
According to the LPC213x data sheets, the timer/counter resets to zero at then end of the match, so the total number of timer/counter ticks will be (T0_MR0 + 1) (except when T0_MR0 is 0). As a quick test, I used T1_MR0 with a prescaler such that the timer1 ticked at 1 Hz, and set the T1_MR0 register to 1 to verify that the reset happens after the match value has completed its cycle.
To fix this, T0_MR0 should be set as follows:
T0_MR0 = ulCompareMatch - 1;
Note that I did not include a check for validity of the final result (ie. non-zero match register) in the above assignment, but that some form of error reporting should be included there.
